camp oven
Submitted: Tuesday, Feb 28, 2012 at 15:43
ThreadID: 92173 Views:2769 Replies:4 FollowUps:1
i got given a camp oven by an overseas traveller and need to know break it in . do i just oil it. would appreciate advice thanks
Reply By: Member - neville G (QLD) - Tuesday, Feb 28, 2012 at 15:54
Gaz,
With a cast iron camp oven I just oil it well, wipe excess oil off and put it in the kitchen oven and crank it up as far as it will go (240c or thereabouts), leave it at that for about twenty minutes, turn the oven off and let it all cool down. You should end up with a nice black glaze to which food will not stick. AFTER COOKING I only wash it out with hot water, I don,t use detergent, dry it and a light oil is all that is necessary ( I use olive but peanut and some of the other oils with a high burn point could even be better).
Cheers, Bundy
AnswerID: 478911
Reply By: baz&pud (Tassie) - Tuesday, Feb 28, 2012 at 15:58
G290
Wipe cooking oil all over the inside of the camp oven, including the underneath of the lid.
Then place on a fire, or over a gas ring and get really hot and this will cure the camp oven, you may have to do it a couple of time to your satisfaction.
Don't wash the camp oven once you have been through the above process, just get a rag and wipe it out.
Happy cookin.
Baz
AnswerID: 478912
Reply By: Member - John and Val - Tuesday, Feb 28, 2012 at 17:46
Hi Gaz,
Lots of info on this site on how to prepare, use and store your camp oven. Just type camp oven into the search box in the top RHS of the forum page and (after a wait of a few seconds) get access to forum posts, blogs, article etc. Its all there.
Cheers ,
Val
J and V
- Albert Einstein
AnswerID: 478926
Reply By: Sand Man (SA) - Tuesday, Feb 28, 2012 at 19:57
Some good info for you here.
Camp Oven Seasoning
Bill
AnswerID: 478943
Follow Up By: Member - gaz 290 - Tuesday, Feb 28, 2012 at 22:20
thanks for all the good advice on camp ovens, i will use it for the first time over easter at stockton beach
FollowupID: 754458
