Another EO TrackMe Question
Submitted: Sunday, Mar 11, 2012 at 21:28
Member - Jack
Image Could Not Be Found
Hi all ..
One for the Tracker gurus.
Late last year I embarked on a trip around
Broken Hill,
Birdsville and environs. Prior to leaving I installed TrackMe on my iPhone. This was to allow friends and family to follow our travels.
The resulting 'plot' only vaguely resembles our travels, having left out more than half of the trip, including our run down to
Adelaide and the trip home to
Newcastle via
Hay and Dubbo.
My question is basically 'what happened'??? It captured part of the trip but not all the detail. I spent a long time checking and double checking all the settings before we left, and also on the road. No improvement.
My only thought is that when my iPhone goes into 'sleep' or 'battery saving' mode it does not send out any tracking signal, but I do not know how to set it up any other way. Is this the problem?
My route can be checked on the EO Track Me page here ... Member Jack .. or I will try and upload a screen dump of that track.
As usual, my thanks in advance.
Jack
Reply By: Mick O - Sunday, Mar 11, 2012 at 21:51
OBJ, from memory you have your Iphone hooked into EO Track me. The Iphone will be operating on 3G so will only register when it has 3G reception. Obviously there are some big holes in coverage on the
Birdsville Track as far as 3G is concerned so what its done is draw a straight line between the two points of reception it got, hence the straight line. Have a look at Equinox's track me. he's got it hooked into a Spot navigator which utilises GPS and gives a faithful track regardless of location
Trackme works very
well on your iphone in urban areas but once into the rural and outback areas where coverage is sparse, she's not so good and you need to move to a dedicated Satnav device such as a spot.
The apprentice
480114
Follow Up By: Member - Jack - Monday, Mar 12, 2012 at 06:50
Hi Mick.
OK. that makes sense, apart from the trip
Adelaide -
Mildura -
Hay - Dubbo - Cessnock. But by then I may have been fed up trying and just switched the phone off. I cannot remember now ... CRAFT disease ....
Thanks.
Jack
755647
Reply By: Member - John D, Wandong (Vic) - Sunday, Mar 11, 2012 at 22:17
Hi Jack,
I have it installed on my iPhone as
well and it works fine at the moment, but that is in and around
Ballarat & Kilmore (Vic), not sure how it would go when out of signal range but when reading the install instructions on ExplorOz I get the impression that the track log is stored in a cache file when no signal is present and updated when back in signal.
You mention about the iPhone going to "sleep" or in "battery saving mode", have you clicked on the uTrackMe app on your iPhone and then clicked the "settings" button (cog symbol in top left corner) and turned "Background Tracking" to "On" to see if this makes a difference?
Regards, John
480120
Follow Up By: Member - Jack - Monday, Mar 12, 2012 at 06:48
Thanks John. I did have background tracking on. Mick O's explanation sounds feasible if my 'sleep mode' theory is wrong, which is what it seems.
Thanks.
Jack
755646
