SPOT trackers
Submitted: Friday, Mar 16, 2012 at 13:55
Yackandandah Holiday Park
Hi all,
I've been trying to set up my SPOT2 device to send OK messages to mobiles but have hit a brick wall. It will send to email addresses just fine, but no matter what i put in the mobile section i just cant get the contact. Does anyone have any experience with this or know how to add correct mobile details? Contact with SPOT has proved no good as the number@provider.com.au suggestion still does not work.
Any advice very much appreciated.
Mick
Reply By: Member - Rod N (QLD) - Friday, Mar 16, 2012 at 14:02
If you haven't already, you need to enter the numbers as the international one for Aus ie 61427 xxx xxx No 0 before the prefix number. 0427 is 61427. Hope you get my drift.
480533
Reply By: Member - Troll 81 (QLD) - Friday, Mar 16, 2012 at 14:06
You need to remove the zero so if your number is 0123 456 789 it should go into the system as +123 456 789
480534
Reply By: Yackandandah Holiday Park - Friday, Mar 16, 2012 at 14:48
Sorted gentlemen,
Thanking you both kindly.
Mick
480535
