evakool ED50
Submitted: Sunday, Dec 21, 2003 at 13:59
ThreadID: 9267 Views:2838 Replies:2 FollowUps:1
Hi I have a eva kool ED50 it cools fine but it continously cycles, it runs for 2 mins and shuts off for four.This seems too much to me. Anyone out there got any info on this it would be appreaceated
Reply By: Mack - Sunday, Dec 21, 2003 at 15:21
Hi Fitch, Your fridge is cycling far too often. To rectify this problem, first locate the thermostat sensor tube where it is located on or near the cold-plate. (The end few inches are responsible for sensing the temperature). Carefully slip some plastic tubing over this end of the tube to insulate it. This "insulation" will slow the tube from sensing a drop in temperature and conversely slow it from rising when the compressor is off. The result will be longer run periods and related longer off periods. You may have to play around a bit with plastic thickness etc to get it right but a loaded fridge should maintain temperature status with no more than two cycles per hour. Your power consumtion will also improve slightly.
G'luck.
AnswerID: 40777
Reply By: Rod - Sunday, Dec 21, 2003 at 21:55
Have you tried calling them ? I've found them quite good on technical stuff over the phone
AnswerID: 40803
Follow Up By: Shaker - Tuesday, Dec 23, 2003 at 16:54
I would call them ... they would have to be the most helpful manufacturer that I have ever come across ..... amazingly if they say they will call you back ...THEY DO! Unheard of these days. I have an EvaKool that had some minor problems & they bent over backwards to help me!
FollowupID: 303528
