1HZ oil line
Submitted: Monday, Apr 08, 2002 at 00:00
ThreadID: 927 Views:3023 Replies:4 FollowUps:2
This is more a warrning than a question.
Owners of toyotas 1HZ 4.2 motor 80 and 100 series , check the oil return line from vacuum pump to top of your motor.
It is a hard line 8mm aprox.dia.It is held in place by only one bracket form factory between vac.pump and fuel inj. pump, and it is prone of droping the bracket bolt and cracking the line under prolonged exposure to corrugations and alike. Bloke i know lost all 9 l.of engine oil in 3 minutes. Only luck saved his pocket from major expenditure.Cheers
Reply By: Andrew - Tuesday, Apr 09, 2002 at 00:00
And you've got the cheek to hang it on Land Rovers. I hope one passes you while you're watching your oil line. BTW I dont own one.
Get lost (I'm being polite)
AnswerID: 2716
Follow Up By: Tojo - Tuesday, Apr 09, 2002 at 00:00
Hey Andrew, at least the toyota owners will be able to find where the oil leak originated from..
FollowupID: 1013
Reply By: goran - Wednesday, Apr 10, 2002 at 00:00
Andrew, that oil leak can only happen to vehicles subjected to months of genuine off roading in hardest conditions on earth and even than its isolated and rare. There , you have nothing to be afraid about, your car is not capable to be exposed to such conditions.
go hide your big ugly head in the sand.It is easier that way.(i am being polite)
AnswerID: 2737
Follow Up By: Tojo - Wednesday, Apr 10, 2002 at 00:00
Hey Goran, lets keep the personal abuse out of this forum mate, I too can sling bad facts about things, which can be of interest to forum users, but the personal abuse should be left in the play ground.
FollowupID: 1040
Reply By: alreadytaken69 - Saturday, Apr 13, 2002 at 00:00
warrning, warrning. nah, zip it.
AnswerID: 2795
Reply By: Bill Church - Monday, Apr 15, 2002 at 00:00
Thanks for the warning, I'm sure that the Toyota drivers will appreciate it. I think this is the first objective post I have seen from you; one that does not sling mud or abuse at other drivers and their vehicles. Remember, you only establish the level of credibility that you deserve on this or any other forum... Bill
AnswerID: 2839
