tv cord amps
Submitted: Thursday, Mar 29, 2012 at 06:38
ThreadID: 92861 Views:1813 Replies:3 FollowUps:1
I have a 12 volt tv which uses 3.3amps. For some reason it won,t operate using a 5 amp lead into a cigiret socket............. which was recommended by the salesman. It works on a .5 lead Is thus dangerous and what amp should we use? Thanks john
Reply By: Member - John - Thursday, Mar 29, 2012 at 07:37
G'day, I would check the 5 amp lead is in fact working.......... maybe faulty?
John and Jan
AnswerID: 481705
Follow Up By: johno59 - Thursday, Mar 29, 2012 at 07:42
Thanks John. I reckon u may be right.It doesn,t make sense. I am going to return it to the store and try a new one. What a great site this is.Fairly new to it. Have had lots of great advice thanks again.
FollowupID: 757022
Reply By: SuperGrover - Thursday, Mar 29, 2012 at 09:07
I had a similar problem and needed a heavier lead. The TV might run at 3.3 amps but the initial startup for a second may need more. If the current is not available the voltage drops and the tv then needs more current. A little like electric motors they draw more on starting than their rated nameplate.
AnswerID: 481709
Reply By: johno59 - Thursday, Mar 29, 2012 at 18:58
Thanks Guys ,had a look at the fuse and it was broken. (A new Item from Dick Smiths ???) It now works OK thanks again
AnswerID: 481772
