Battery monitor problem
Submitted: Thursday, Mar 29, 2012 at 17:50
ThreadID: 92876 Views:2225 Replies:1 FollowUps:0
Hi there. I've just installed the piranha dual battery monitor but it has a problem. It is only showing a voltage on the aux battery when the batteries are connected via the piranha dbe170, which isn't the voltage of the single battery. The main battery is showing the voltage fine. Any ideas?
Reply By: Dennis Ellery - Thursday, Mar 29, 2012 at 19:36
I would imagine that the piranha dbe170 connecting the two batteries is an electronic isolator - if that is the case then there will be a voltdrop across the isolator of around half a volt. If it was mechanical isolator like the Redarc it would be virtually nil for most conditions.
AnswerID: 481778
