Monday, Apr 02, 2012 at 14:32
G'day Stan
As the others have said, you need to test the amps for a long period to get the full picture.
If the Engel is the same compressor as is normally used then it draws around 2 amps when running, some do vary a little fridge to fridge. You mentioned something which puzzles me a little and I have heard this before where it says they draw between, as you stated 0.5 and and 3.5 amps. Do you mean this as the average of the hourly use or the actual current draw. Unless this is clearly understood which is which then problems are harder to advise on.
I always go on the current draw because this is what can easily be tested and because the use/run time can vary enormously and flatten the battery far quicker than you thought it would.
Seeing you are travelling, perhaps the vehicle ambient temp the fridge is working in is quite warm and therefore the fridge is running far more often and for longer than you think it is. feeding fresh cooler air might nearly double battery charge run time.
If one fridge is dropping the battery voltage too low in a short time it must be the batteries are either not being charged to capacity or they are not capable of holding their design charge capacity.
PS Many battery testers will put a load on a battery and they say it is good when in fact it is not, makes you doubt battery testing people and their proficiency.
Only you can truly assess the situation of your fridge and batteries.
757432
