new Prado. limited space between tyre wall and suspension
Submitted: Tuesday, Dec 23, 2003 at 19:47
wal30_au
Hello, has anyone experienced any problems with the small space between the tyre wall and the front
suspension arm, on the latest model Prado? It is only approx 10mm (you can't even run a finger between the tyre and the
suspension arm). Does this pose a problem at low pressure (ie. sand driving)? It would appear snow chains cannot be fitted to the front tyres. Are snow chains required on all tyres or is having them fitted to the rear sufficient?
Thankyou for your feedback. Wal...........
Reply By: Bob Y. - Qld - Tuesday, Dec 23, 2003 at 21:53
G'day Wal,
Dunno about chains in the snow, have only ever used them in mud.
One problem I can see with that lack of clearance, is if you got caught in some wet, heavy, blacksoil country. That would seriously impede your progress, and may possibly, stop you all together. Only if it was raining, or ground very wet, read sloppy, would you be mobile.
Sounds like sand driving might have some dramas too. Maybe someone here has used their newy in the dunes?
Happy Christmas
hooroo...
40998
Reply By: Phil G - Tuesday, Dec 23, 2003 at 22:30
When a tyre's flat, or you air down in sand, last time I looked it was only the bottom part that bulged out :-))
41001
Follow Up By: Member - Bob - Tuesday, Dec 23, 2003 at 22:42
Thats when you are stationary and looking at it. But what happens when you drive off? You can't tell me the flat bit doesn't go round and round.Bob
303566
Follow Up By: Member - Ross - Wednesday, Dec 24, 2003 at 09:37
Only way to tell though is by the bumpy ride.Fidei defensor
Rosco
303588
Reply By: Truckster (Vic) - Tuesday, Dec 23, 2003 at 22:42
Have a look at www.offroader.com.au
steve has done lots of mods, including 285's on his Playdoe, all is documented in the last 1-4mths archives.
41002
Follow Up By: Phil G - Tuesday, Dec 23, 2003 at 22:55
Truckster,
Steve has ROH
wheels which are offset outwards, increasing clearance
303571
Follow Up By: wal30_au - Tuesday, Dec 23, 2003 at 23:39
Thanks Truckster,
Have tried to find archives in offroader
forum but have been unsuccessful.
Must be quite simple but can you steer me in the right direction maybe some search keyword?
Regards Wal..
303575
Follow Up By: Truckster (Vic) - Tuesday, Dec 23, 2003 at 23:48
Looks like his archives are a little fubar at the moment, Ive mailed him!
Try again maybe next few days.
Failing that try the Prado list on Yahoogroups. www.yahoogroups.com and search for Prado or 90scool
303576
Follow Up By: Phil G - Wednesday, Dec 24, 2003 at 15:48
Truckster, theres 3 Prado groups now.
The Yahoo one for the 120 series is called "120scool".
There are 2 for the 90 series Prados. The long standing one, which was called "90scool" is now called "90series" while a new one called "90scool_aus" has just started.
The 120series wheel info is in the technical section at www.lcool.org
303609
Reply By: Thommo - Tuesday, Dec 23, 2003 at 23:07
Wal,
the 90 series indicates in the manual not to put snow/mud chains on front tyres, for same reasons, not much clearance.
On put chains on rear, not the way to go, but better than nothing, drive more carefully and have the best tyres for the conditions.
Thommo.
41006
Follow Up By: paul - Wednesday, Dec 24, 2003 at 12:35
I was led to believe you shouldn't put chains on the front of the 90 series cause it buggers up the AWD diffs. maybe i wuz told wrong and now i have my
suspension lift i should invest in a set of chains.
303595
Reply By: maverick - Wednesday, Dec 24, 2003 at 18:11
somewhere back a few posts is someone asking about changing tyres on his new Prado - same problem - no distance between
suspension and tyre wall. Don't you just love these new 4WDs???????? and yes no snow chains. rgds
41060
