Air Conditioner as Compressor
Submitted: Friday, Jan 02, 2004 at 12:06
Justin
Hi all. I have seen a stock A/C Compressor mounted as a Air compressor(poorman's endless air). Seemed like a pretty good way to go. Is there any way of doing this with a Standard Air conditioning unit and still have the Air con Work or will I nedd to mount a second unit?
Justin
Reply By: Member - Ross - Friday, Jan 02, 2004 at 12:41
Justin
You'll need a second unit if you have the space, which I doubt ... unless it's an old beast. The A/C unit is part of a sealed system compressing refrigerant. You'll need an extra one to compress air. And you'll need an extra drive pulley to take the belt or a VERY long serpentine belt if that's the case.
I've seen them myself and they certainly seem to do the job.
CheersFidei defensor
Rosco
41546
Reply By: Justin - Friday, Jan 02, 2004 at 14:37
Nah Got plenty of room under the bonnet of the 60 Series. I don't really want to ditch the A/C. I take it it's a matter of fabricating a bracket and running a belt to accomadate and away I go? Is there anything else that needs to be done to the compressor?
Justin
41557
Follow Up By: Member - Eskimo - Saturday, Jan 03, 2004 at 09:08
Get a bracket from the aircon specialists.....unless your an engineer you'll only find that the one you make may break causing all sorts of headaches when your a long way from home.Wow! am I cute
If yer ain't fishing, Yer ain't livin
Richard
304110
Reply By: Nav 80 - Friday, Jan 02, 2004 at 14:47
Used one myself once,and it did a good job but as has been mentioned on the later vehicles room is the problem. Cant remember where I saw it but someone like ORE has done an adapter kit to fit one off the sump bolts I think. You also have to run a bit of oil through the compressor now and then as they are lubricated by the air con gas. Unless you can fit it yourself you will find the cost involved would be as much as the cost of a good portable compressor 12v There are some good units on the market today.
41559
Reply By: Truckster (Vic) - Friday, Jan 02, 2004 at 14:59
Search the archives, been done heaps of times. Google has 19024821039482103498 of hits on it too
Use a Sanden 508 Compressor...
Cant be done on 3.0 GU's.
41560
Reply By: Mick - Saturday, Jan 03, 2004 at 15:04
Ive done it myself in the old gq & Mq with the sanden sd508 comp, i filled it partially with oil and fitted a
water separator on the outlet line so the oil and
water could be drained out every once in a while, depending on how often i used it.
The other thing to do is strip the compressor and block the small oil lube pipe which pumps it back through the system. I havent tried it yet as my new trucks the GU, but i have stripped an old one & found how to do it, quite simple.
Endless air supposedly remove the old bearings and fit fully sealed bearings in them but VERY xxy!
41646
