what size spanner
Submitted: Saturday, Jan 03, 2004 at 15:12
ThreadID: 9469 Views:1829 Replies:2 FollowUps:1
what size spanner do i need to undo the manual transmission drain and refill plugs on a troopcarrier 4.2 diesel hjz75 . and does anyone know if the plugs on the trasfer case are the same size . any help appreciated .
regards gleno
Reply By: Bob Y. - Qld - Saturday, Jan 03, 2004 at 15:29
Glenno,
All the Tojo plugs should be 24mm or 15/16"AF, for both diffs, g'box and t/case.
Don't use too much force to do them up again, or they'll be extremely difficult to undo later. Have seen plenty end up "round", requiring the welding of another nut on to remove them.
Gregory's manual says "37 Nm for drain and filler plugs"
Hooroo...
AnswerID: 41648
Follow Up By: Bob Y. - Qld - Saturday, Jan 03, 2004 at 15:31
"49 Nm for Diff plugs", suppose g'box tension is less because of alloy case.
Hooroo...
FollowupID: 304119
Reply By: glenno - Saturday, Jan 03, 2004 at 15:46
thankyou regards glenno
AnswerID: 41652
