Caravan Annex Walls
Submitted: Monday, Apr 09, 2012 at 07:54
Member -Carl R (QLD)
The annex walls on our caravan has a white strip of vinyl approx 100mm moulded to the bottom of each wall, are these suppose to fold inside or outside
Reply By: Fred G NSW - Monday, Apr 09, 2012 at 08:49
I fold
mine out. Helps with
water run off encroaching into the annexe.
Fred.
482572
Follow Up By: Member -Carl R (QLD) - Monday, Apr 09, 2012 at 09:04
That was my thinking
757853
Reply By: Member. Rob M (QLD) - Monday, Apr 09, 2012 at 17:18
Hi Carl,
Mine has a strip closer to 200mm wide at the bottom which we fold into the annexe, otherwise we cannot drive in the pegs at the bottom.
Rob
482610
Follow Up By: Fred G NSW - Monday, Apr 09, 2012 at 18:04
Rob, my annexe skirt has eyelets purposely placed in the skirt, to allow pegging down. There is provision for pegs via tags at the bottom of the wall, as
well as the skirt. Best annexe I've ever had. Made in WA. It is also 2.7m wide rather that the standard 2.4m.
757886
