Wind deflector for Rhino basket
Submitted: Saturday, Apr 14, 2012 at 10:06
gra.cahill
When travelling on longer outback trips I don't really want to tow a trailer. My solution was a set of roof bars and a rhino basket. The problem? Its noisy and really hits
fuel consumption! Any ideas on the best way to make a wind deflector. Tried the local sheet metal fabricators, but couldn't get in past the guard dogs (guess they have enough business to keep them busy!) I thought of some polycarbonate which I understand can be heated and then bent. Aluminium is another possibility. Anyone done anything similar?
Any ideas where to go to get the materials or to get something made at a reasonable price?
Reply By: spudseamus - Saturday, Apr 14, 2012 at 11:23
this is an old chestnut -- are the bars sq in shape ? if so attach that black pipe insulation around the front bar and if the basket is a mesh wire type put a cover over it -- that will soften the wind noise ! as for the
fuel issue the best way of dealing with it is knock 5 to 10 ks off your speed ! this will do more than fitting any bit of sheetmetal to the top of the roof !
483073
Reply By: The Bantam - Saturday, Apr 14, 2012 at 11:31
one thing to think about is PVC pipe.
Find some of the appropriate diameter and slit it up the middle on a saw bench or carefully with a jigsaw, you can use plumbing fittings for the ends..cut the back of them away likewise.
remember it is easy to heat mould so you could leave attachment tabs and shape them with heat.
wipe with thinners and then prime with thinners bassed primer and paint desired colour.
483074
Follow Up By: The Bantam - Saturday, Apr 14, 2012 at 11:32
OH another option for the bars..if the bars supplied are square or rectanguar, replace them with oval shaped "cattle rail"
758279
Follow Up By: gra.cahill - Saturday, Apr 14, 2012 at 12:32
Thanks,
Hadn't thought of using pvc pipe. Any suggestions on how to heat it to mould it to shape? Might also be possible to use a large pipe outside a smaller sealed inner pipe that could be used for a source of non-
drinking water.
758282
Follow Up By: The Bantam - Saturday, Apr 14, 2012 at 13:02
A heat gun will easily deal with small parts, but a bit of an ask to bend full sections bigger than 50mm though.
Plumbing pipe is not as forgiving as electrical conduit so a carefull touch is required.
the heat gun will be fine for bending out tabs and shaping attachments.
personally not all that keen on
water that high
rewmember the rated load of a good rack is a bout 50Kg per bar and most roof structures are only rated at 100kg total.
758286
Reply By: Mick O - Saturday, Apr 14, 2012 at 13:07
Given your tight time frames I would highly reccomend Brown Davis in Bayswater. Kevin Sharp is the go-to man.
Brown Davis Automotive
Cheers Mick
483079
Follow Up By: gra.cahill - Saturday, Apr 14, 2012 at 14:19
Hadn't thought of Brown Davis. My side steps, underbody protection and long range
tank come from them. I will give them a try. Thanks.
758296
Reply By: gra.cahill - Monday, Apr 23, 2012 at 12:37
Problem solved. Local TJM suggested a plastic fabricator in Bayswater. Had a deflector made from dark
grey polycarbonate. Just measured the size required and the angle (using a free iPad app!) and they bent the polycarbonate for me. Looks quite neat and has made a substantial difference to wind noise. Hopefully that will translate into lower
fuel consumption!
483913
