C F 60 waeco reading 60c
Submitted: Sunday, Apr 15, 2012 at 16:24
Drummo
Having problems with 60 litre Waeco . Reading 60c and freezing everything , compressor constantly running on 12v and 240v.. Leaving
Karumba for
Cairns in a few days and would to have it look at / repaired before we leave for
Cape York in a few weeks time.Any advice very welcome.
Reply By: cookie1 - Sunday, Apr 15, 2012 at 17:24
My first thought would be the "Emergency Override" button which will keep it running
Colin
483199
Follow Up By: dbish - Sunday, Apr 15, 2012 at 19:27
If its reading 60deg & running continously & freezing, it will be the thermistor faulty.
758458
Follow Up By: Teejay - Sunday, Apr 15, 2012 at 20:45
I agree dbish. My Waeco 50 did exactly the same. About a $130 repair.
758468
Follow Up By: Drummo - Monday, Apr 16, 2012 at 08:07
thanks, will try for repair in
Atherton or
Cairns
758494
Follow Up By: Member - Ray Mc (WA) - Wednesday, Apr 18, 2012 at 08:52
Like Teejay, my Waeco 50 had the exact problem you speak off Drummo. It then went to not working at all. $150 repair in
Perth which only took about 30 minutes. Seems like a common problem as repairer diagnosed it over the phone and confirmed problem through testing. Other than that issue, fridge has been and is good as gold.
758681
Follow Up By: Member - Roy E (QLD) - Wednesday, Apr 18, 2012 at 21:46
Just recently had my CF80 do the same, the guys at Waeco made short work of the repair (replacing the thermistor) they also did a mod which involves the thermistor being placed in a tube which protects it from being damaged by ice buildup and also means it can be changed easily through the front grill rather than having to take the thing apart to get it out, apparently the new CF80's have this mod from the factory.
Fortunately Waeco have a workshop and refurbished/seconds outlet here on the
Gold Coast which is where I purchased the CF80 a few years ago, they also fixed it next day after they opened the workshop for me when I arrived just after closing which was great because we were going on a trip that weekend.
Roy..
758750
Follow Up By: Dadonbike - Thursday, Apr 19, 2012 at 00:07
I just had my CF50 repaired for a similar issue. Cause was due to moisture/
water in the control panel. There is a small hairline gap along the control panel cover where it screws into the fridge body. Ours started playing up immediately after having
water drip onto this gap (while it rained). This was the only time it had ever gotten wet and started displaying wrong temperature and freezing everything within a day or two. Repaired (under warranty).
758759
