Solar Specialists in Bunbury ( WA ) area
Submitted: Wednesday, Apr 18, 2012 at 23:15
Brian
Hello all ,
i have a solar setup in my old van , couple of roof panels , battery , inverter etc . van has been sitting idle for a while and when i tried to use the solar on the fridge it wasnt working so obviously i need someone who know their stuff to have a look at it , can anyone reccomend a solar specialist in the Bunbury area . Am prepared to go either direction if need be such as
Busselton or Mandurah ??
Reply By: Member - bungarra (WA) - Thursday, Apr 19, 2012 at 17:45
unusual for a "solar setup" to stop working.
Hard to tell from your post what the facts are but reading between the lines are you sure it is not simply the battery not charged?.
These is no real reason why solar panels regulators etc stop working (read charging batteries) apart from physical damage (rats/mice on the wiring)...rubbing chaffing etc...blown fuse in the line somewhere...loose connection causing a bit of "bloom" on the wire connection.
I would be doing some simple tests yourself first before I dragged it somewhere and get charged for some basic checking. Get a multimeter and see if the panels are sending current to the regulator and simply work your way through the system..shoule be quite simple to find the error.
483566
Follow Up By: energy marty - Friday, Apr 20, 2012 at 08:54
I concur
758897
Reply By: Member - thekettles - Thursday, Apr 19, 2012 at 19:32
Hi Brian,
You could try Rods Auto electrics in
Busselton.
I had trouble with my solar not charging batteries and they got it sorted.
483583
Reply By: landseka - Friday, Apr 20, 2012 at 12:12
If it becomes necessary to go to a store, there is a Solar
Shop in the block of units on the North East corner of Albert Rd & Strickland Street next to the lunch bar.
I've never been in it but saw it last week on my way past.
Cheers Neil
483651
Reply By: Brian - Sunday, Apr 22, 2012 at 22:23
many thanks to those who replied , havent got it sorted yet but once i do will let you know
Brian
483875
