RA Rodeo - Where are the 4WD actuators?
Submitted: Sunday, Apr 22, 2012 at 07:28
Member - Greg A
Hi All,
I notice that if I haven't selected 4WD for quite a while it takes several tries of switching between 2wd and 4wd before it successfully selects 4wd.
I'm guessing that there is some sort of actuator that is possibly gummed up through lack of use and needs a clean/lubrication?
Does anyone know where this is located so I can have a look at it?
Thanks in advance,
Greg..
Reply By: Alloy c/t - Sunday, Apr 22, 2012 at 07:47
Try the reset , ,,, Ign off - press in and hold in all 3 buttons while turning ign on [do not start motor] , hold buttons for 30 seconds then turn ign off and release buttons , ,,,, start car as per normal , select drive required ,,,,,,
483804
Reply By: Member - batsy - Sunday, Apr 22, 2012 at 07:57
The actuator/solenoid is located on the left hand side just above the axel tube.Pull the rubber cover off,pull the connection wires off & coat with Permatex Dielectric grease.After having done this to my Rodeo I had 220,000 trouble free km;s including a lot of
water crossings.
Batsy
483808
