V8 Troopy Water Tank
Any ideas for fitting an under body water tank to a 2008 GXL Troopy, or anybody know of any available for sale?
Reply By: Michael A (VIC) - Thursday, Apr 26, 2012 at 07:45
I haven't seen one on the 08 model, but the one I saw was from Long Range Automotive and it looked like it would fit under my 08 GXL Troopy. It tucked up underneath on the drivers side toward the rear axle.
I went for a 60 litre water tank that sits inside in front of my fridge.
Michael A
AnswerID: 484244
Reply By: Ozhumvee - Thursday, Apr 26, 2012 at 08:32
We fitted a 50 litre bladder in the space between the inner cardboard panel and outside skin in the section on the passengers side between the door and rear wheel. the cardboard panel was replaced with thin ply, filler neck was at the top under the window and the drain tap was at the rear of the running board.
We also replaced all the cardboard panels with thin ply with access holes to store stuff in the other panels including the rear doors.
The same space on the drivers side can hold four five litre containers of oil.
AnswerID: 484250
Reply By: Bob Y. - Qld - Thursday, Apr 26, 2012 at 10:30
If you Google the following, there maybe a tank to suit your requirements:
Dolium Tanks
Poly Rv Tanks
Snake Racing (they look to have a new line of tanks/jerricans now)
All the above are poly tanks. I've got an 80L water and 80L fuel tank made by Poly RV, that I bouight from TJM, in Townsville. These would not suit your troopy, but other tanks they have might. Paid $350 - $400 for the above tanks.
Bob.
AnswerID: 484257
Reply By: Harry - Thursday, Apr 26, 2012 at 22:34
Fitted 55L stainless behind the rear fuel tank. This tank has been under 3 Troopies including 07 V8 and current model. Electric pump pulls the water up to inside back door tap. Pump is mounted near the back door and inside away from the elements.
Harry
AnswerID: 484327
Follow Up By: Geoff (Newcastle, NSW) - Friday, Apr 27, 2012 at 00:36
Hello Harry,
Who made your tank?
Geoff
Geoff,
FollowupID: 759596
Follow Up By: Harry - Monday, Apr 30, 2012 at 17:37
G'day Geoff,
Away for the weekend having fun so hence you didn't hear from me. It was made privately, but if I send you dimensions and a couple of pics how does that sound. Send me your email if you want those details.
Harry
FollowupID: 759902
Follow Up By: Geoff (Newcastle, NSW) - Monday, Apr 30, 2012 at 20:40
Hello Harry,
Sounds like a great deal to me!
Email is: Geoff at Mullard dot id dot au
Replace at with @ and dot with .
thanks again,
Geoff
Geoff,
FollowupID: 759913
Follow Up By: Harry - Monday, Apr 30, 2012 at 20:47
Geoff,
got all that, will try the address given, otherwise will be back here.
Harry
FollowupID: 759914
Follow Up By: Geoff (Newcastle, NSW) - Tuesday, May 01, 2012 at 21:45
Thanks Harry,
Git the enail, all looks great!
Geoff
Geoff,
FollowupID: 760028
Follow Up By: Harry - Tuesday, May 01, 2012 at 22:35
Geoff, use the reply email to talk
FollowupID: 760032
Follow Up By: craigandej - Thursday, May 10, 2012 at 23:36
would love details/pics of the above tank with dimensions. Could you email me please
FollowupID: 760775
Follow Up By: Harry - Friday, May 11, 2012 at 09:08
G'day Craig,
Give me an address.
FollowupID: 760785
Follow Up By: craigandej - Friday, May 11, 2012 at 20:06
craigandej@bigpond.com
FollowupID: 760832
