Jayco Flamingo ST
Submitted: Saturday, Apr 28, 2012 at 15:53
ThreadID: 95217 Views:2909 Replies:3 FollowUps:1
How hard is it to install guage to the water-tank
Reply By: Member -Dodger - Saturday, Apr 28, 2012 at 16:46
If the water tank is of the plastic type then it is very simple.
When you purchase the water guage they come with fitting instructions.
Cheers Dodg.
AnswerID: 484458
Reply By: Member - Shane D (QLD) - Saturday, Apr 28, 2012 at 21:27
I have a Jayco swan, The previous owner put on a clear plastic filler pipe, All i have to do is crouch down and have a look at high the water is up the pipe, not as convenient as a gauge but does the same job
Shane
AnswerID: 484492
Follow Up By: Shaker - Sunday, Apr 29, 2012 at 09:38
Clear pipe is a bad idea, as it will grow algae on the inside which will make it's way into your tank!
FollowupID: 759801
Reply By: member-PradoMad - Sunday, Apr 29, 2012 at 08:23
Jayco has a good forum that covers most issues, you might want to try that.
http://forum.jayco.com.au/forumMessages.asp
JS.
AnswerID: 484513
