3" Exhaust system upgrade for 100 series T/D auto
Submitted: Wednesday, May 02, 2012 at 23:30
Member - Ian G (NSW)
I am considering the above modification as I now tow a (approx) 3 tonne off road c'van.
Can anyone advise what improvement in performance I could reasonably expect. I am looking more to better overtaking/towing/economy. Is this a reasonable expectation?
The vehicle is 2006 model with a DP chip fitted.
I have been quoted $800 supply and fit including a stainless steel muffler. The business owner said he does mandrel bends only where bend angle is more than 45 degrees. Does this sound normal? The price is certainly attractive.
Appreciate any advice/comments.
Reply By: Member. Rob M (QLD) - Thursday, May 03, 2012 at 09:01
Hi Ian,
I have the same vehicle and had a 3" mandrel bent system installed by
Beaudesert exhausts about 12 months after I purchased it.
I don't have any exact figures for you unfortunately, but I definately noticed a difference in the whole feel of the vehicle, especially when on long inclines and the like. It seems to hold gears longer before kicking down.
You will notice the sound of the exhaust is quite a bit louder, but not unpleasant.
I didn't chip
mine but had gas injection installed which according to the dyno figiures gives 10% more power and 12% more torque. The added benefit is it burns a lot more of the diesel rather than putting it out the exhaust and apparently stops the oil from sooting as much giving a little more leeway as to oil change intervals.
I must admit I can't see why you would not mandrel bend the entire exhaust if you are going to do some of them.
484874
Reply By: Life Member - Phil B (WA) - Thursday, May 03, 2012 at 10:44
Hi Ian
I would probably go for a ready made and proven 3 inch exhaust from someone like Taipan or
Beaudesert. Having one bent up for you may not give the best result. I can't quantify that in anyway but feel its worth mentioning.
I got a Taipan and chip for my 2006 TD 100 series and I got an extra 20 KW and
73 Nm torque.
484884
Reply By: baz&pud (Tassie) - Thursday, May 03, 2012 at 11:51
We are not diesel, have a V8 petrol 100 series with a 3" exhaust fitted and you will notice the difference, hangs on for a longer period and also you will notice the difference in performance, the only problem is that you get used to it and you then want more.
Baz
484888
Follow Up By: Member - nick b - Thursday, May 03, 2012 at 21:01
baz&pud , what
fuel consumption to you get - before & after ?
regards nick
760198
Follow Up By: baz&pud (Tassie) - Friday, May 04, 2012 at 08:52
Nick,
To be honest with you, i don't worry about
fuel consumption, cause i take the attitude that i have to get there, what ever the cost.
Having said that, the only time i keep figures is when travelling on the northern island, and towing a van last trip (2011) we averaged 4.55 ks per litre. which works out to about 22 litres per 100ks.(i think).
Baz
760218
Follow Up By: Member - nick b - Friday, May 04, 2012 at 21:19
thanks baz&pud for the reply .
I presume you dont know if the
fuel consumption is better with 3" exhaust ....
when you know
fuel consumption then you know how far you can get on a
tank .....etc cheers
760260
Reply By: Member - Richard W (NSW) - Friday, May 04, 2012 at 07:56
Ian,
FWIW I have posted this before and it shows the stats I have kept on my
fuel consumption with various mods added in order.
1) Standard
2) Tyres 285X75X16 muds (stats normalised for the larger tyre size)
3) 3" Exhaust
4) D'tronic Chip
5) Camper Trailer (750KG GVM)
Exhaust improved mid range performance but not
fuel consumption.
Chip improved both low end performance and
fuel consumption.
High
fuel consumption was 4WD tracks.
484937
Reply By: murrayman - Friday, May 04, 2012 at 08:20
Hi ian, i have a cruiser the same as yours. my off road van weighs 3400kg loaded. I fitted a 3"
beaudesert exhaust and it improved the pulling power up hills no end. It also hangs on much better. No difference in
fuel economy, im consistent at 20 lites per 100. The only time my
fuel usage is lower is when i am in the Flinders or on cold crisp mornings it goes like a cut snake and has been as low as 16 l per hundred. A bigger inter cooler would be the next mod iff i do any. The
beaudesert exhaust was the sweetest thing to fit, 2 hours to remove the old system and fit the new including dump pipe. cheers mark
484939
