Hema GPS
Submitted: Thursday, May 03, 2012 at 18:29
Member - Tony Z (NSW)
Hi all.
I have a Hema H5i and having trouble finding where or what screen you need to be in, to input GPS Co-ordinance for destinations given in mags & and on here. I have misplaced the manual and can handle doing most other steps but this has got me!
Can anyone help me please and thanks in advance
Reply By: The Explorer - Thursday, May 03, 2012 at 18:40
Hi Tony
If you are referring to when using OziExplorerCe then to enter a coordinate manually, one way is to create a "dummy" waypoint and then use the edit function to change the coordinates to match what you have. If you get stuck on that get back for more detailed instructions.
PS - Much easier to do it on the home PC with Ozi first and then transfer waypoints..but of course that is not always an option.
484914
Reply By: Allan B (Member, SunCoast) - Thursday, May 03, 2012 at 23:41
Hi Tony, You can find the Manual and other help
here.
484930
Reply By: Member - DEREK K - Friday, May 04, 2012 at 05:22
Hi Tony
I had same problem , got around it for a one off local trip by using the street map screen, first go to create route thenyou have your start point then hit the plus button then moreat the bottom of screen ,you should then have coordinates come up hit that and then you can put in.
Other than that for putting on other maps i think you use the computer tocreate waypoints then transfer to gps
484932
