Wednesday, May 09, 2012 at 13:32
I agree with GTC about Long
Ranger's reputation. When they say "140 litres" I would confidently believe that is the liquid
fuel capacity from a bone-dry
tank to full. Trying to determine the
tank capacity by calculating from driving and consumption is very inaccurate.
Rcam, if you really want to verify the
tank liquid capacity you would need to drain the
tank via the drain-plug then accurately measure the quantity of
fuel to fill the
tank. Whilst doing this you would also be able to determine how much
fuel is required to extinguish the low-
fuel lamp and also the gauge indications as the
tank is filled.
In my own case as a test, I continued to drive after the low-
fuel lamp came on until the engine starved. This was about 50km so I now know how much reserve I have below "empty" indication.
In the other direction, with an absolutely full
tank I drive about 100km before the gauge starts to move down from the top stop which is satisfactory. The overall calibration is therefore fairly reasonable but I believe it more important to have the gauge and lamp most accurate at the lower end.
Incidentally, it was necessary to have an automotive engineer verify and issue a vehicle modification plate for the
tank installation. I understand that it was his requirement that the
tank be filled with
fuel as part of his inspection. I would expect that Long
Ranger would also specify this as part of the installation. If, as in my case, this were done the
fuel fill would verify the
tank capacity.
760607
