polystyrene blocks where in perth
Submitted: Friday, May 11, 2012 at 10:07
sub
hi
does any one know where i can buy blocks of polystyrene foam from in
Perth.North of river.
It is for under floor floatation in a boat.
also the best place to get marine ply from.
regards Dean
Reply By: Life Member - Phil B (WA) - Friday, May 11, 2012 at 10:18
Hi sub
For marine ply try Cullitys balcatta
Sorry cant help with foam
chers
485514
Reply By: franken - Friday, May 11, 2012 at 10:30
If you go to Ewing, Radium or Mills St in
Welshpool (I've forgotten which one) there is a mob who deal in coolroom panels. They often have FREE foam sheets on the verge from panels that have delaminated. Thickness is usually 50, 75 and occasionally 100mm.
They are on the LHS when travelling from
Welshpool Rd towards the railway line.
485515
Reply By: Dennis Ellery - Friday, May 11, 2012 at 12:16
A couple of years ago I purchased polystyrene foam (normal building variety) and used it as a float in a hydroponics setup. It slowly absorbed
water and once saturated I couldn’t get it out. I then purchase more foam and had success sealing the foam with an expensive paint-on waterproof membrane. If you want the open cell foam they use for cool rooms and building panels – Clarke Rubber sell it. If it was for a safety device I would try and find the closed cell product.
485533
Follow Up By: Dennis Ellery - Friday, May 11, 2012 at 12:19
You will notice the difference in the two types of foam - cut a fish pot float and notice how dense and heavy it is compared to builders foam.
760796
Reply By: Shaker - Friday, May 11, 2012 at 18:06
Why not use pouring foam as boat manufacturers do?
485562
Reply By: Bill BD - Friday, May 11, 2012 at 22:39
Yep, the high density stuff is double the price. I bought some sheets from
Foamsales in Balcatta. They probably sell larger blocks but I didn't see any at the time. I got the higher density styrofoam to act as an insulating backing to some van wall panels I installed.
485600
