Waeco Fridge
Submitted: Friday, May 11, 2012 at 13:48
ThreadID: 95496 Views:3346 Replies:5 FollowUps:0
Can anyone recommend a fridge mechanic to fix the control panel on a waeco fridge. Ours has decided to stick on one setting and wont change. So have to switch it off and on or have everything frozen.
Cheers Mandy
Reply By: Mandy B - Friday, May 11, 2012 at 13:52
Sorry should of said in Townsville.
AnswerID: 485543
Reply By: Allan B (Member, SunCoast) - Friday, May 11, 2012 at 14:11
Hi Mandy,
Try these Waeco service agents:
Townsville Caravan Repairs
67 Bowen Rd
Rosslea 4812
QLD
Phone 07 4779 0566
Or
Name Sun City Refrigeration Service
33 Pilkington St
Garbutt 4814
QLD
Phone 07 4779 8999
AnswerID: 485544
Reply By: Dennis Ellery - Friday, May 11, 2012 at 14:31
Mandy
Male sure your emergency override switch hasn't been turned on.
AnswerID: 485545
Reply By: GG7777 - Saturday, May 12, 2012 at 17:17
Mandy
If your fridge is an early one with the row of lights to indicate the temp (rather than the newer ones with a digital temp display) an easy fix is to remove the cover and change temp by the buttons underneath.
To do this open the lid and with a small screwdriver remove the two screws holding in the control panel, using a match or fine pointed tool push the "insert" back up & then change temp by using the buttons directly.
I have actually removed the "inserts" and left the cover unsecured thus allowing me to alter temp by this method every time
Hopew this might be a cheap and easy fix
Murray
AnswerID: 485644
Reply By: GG7777 - Saturday, May 12, 2012 at 17:19
Mandy
Murray
AnswerID: 485645
