Funny elec problem /Patrol
Submitted: Friday, May 25, 2012 at 15:52
pepper2
If i turn on the headlights the left indicators switch on (constantly on not blinking) without me useing the indicator switch,RHS operates normally.With headlights switched off all works normally.This has only recently occurred.
I would be greatful if anyone can offer any suggestions,Thankyou
Reply By: ABR - SIDEWINDER - Friday, May 25, 2012 at 16:13
Sounds like a bad earth, easy fix.
Derek
486768
Reply By: Allan B (Member, SunCoast) - Friday, May 25, 2012 at 16:36
Derek is probably right, but a couple of questions to confirm.
1. Do both front & back turn indicators come on with the headlight?
2. Is the left headlight coming on at reduced power?
If yes to both then it certainly is an earth return connection fault. The left headlight and left front indicator must be sharing the same connection to chassis and this connection is poor. Trace the earth return wire from your left headlight to the point where it connects to the chassis. Remove the connection and clean it then remake the connection firmly. The earth return wire from the headlight may be enclosed within a loom but if you follow the loom a little you may find a wire leaving the loom to connect to chassis.
If all else fails, identify the earth return wire at the headlamp and connect a wire to it, then connect this new wire to a good earth point on the body/chassis.
486772
Follow Up By: pepper2 - Saturday, May 26, 2012 at 09:42
yes both indicators are illuminated,the headlights are both alight and equal
762029
Follow Up By: Allan B (Member, SunCoast) - Saturday, May 26, 2012 at 12:08
Then it doesn't sound like a common earth fault problem. It is more likely an unwanted connection between your headlight circuit and the left indicator circuit.
As others have said look to your combo switch.
If it were a crossover short in the trailer plug as Shaker suggests then the indicators would come on with just the
parking lights as
well as the headlights as there is no headlight wire in the trailer plug, only parkers.
762034
Reply By: Shaker - Friday, May 25, 2012 at 22:10
Check your trailer plug wiring. (If fitted)
486780
Follow Up By: pepper2 - Saturday, May 26, 2012 at 09:43
thankyou will check it out
762030
Reply By: Witi Repartee - Friday, May 25, 2012 at 22:32
I had a similar problem in my GQ Patrol. Replaced the indicator/light switch...problem solved for a few months, then it reappeared.
Took it to my local Auto Sparky...he also replaced the above switch..but tweaked it slightly. He said to keep the receipt as the switches are notoriously fickle..and I had a years guarantee on the job he did.
486783
Reply By: olcoolone - Friday, May 25, 2012 at 23:16
So I take it as a MK... or is it a GU.... maybe a GQ?
Year made or model goes along way to obtaining information.
486785
Follow Up By: pepper2 - Saturday, May 26, 2012 at 09:44
Yes you are correct it is a 2007 GU auto 3 litre
762031
Follow Up By: olcoolone - Saturday, May 26, 2012 at 13:33
More then likely an earth problem. there is a common black wire to your headlights and indicators...... the left side has a separate earth point to the right.
What you can do is get a bit of insulated electrical wire and make contact with the black wire on the headlight globe holder and the negative on the battery.
If your problem disappears then you have to start looking for the earthing problem.
Just to note your left hand indicator should have the following wires:-
Green/yellow +
Black -
And your headlight should have the following wires:-
Red/green Low beam +
Red/blue High beam +
Black Earth
The earth point for the left hand side is the 10mm bolt behind the left hand headlight on the inside guard, the right hand side is the same but on the right hand side.
Hopefully that helped, any other questions just yell....
762042
Reply By: Member - Bucky - Saturday, May 26, 2012 at 04:45
That could
well be an earthing problem !
Try and locate the main earth, from the battery, remove it and scratch up the metal alll around the bolt and
the nut it attatches.
OR
Get another earth strap, that can bolt to the motor, with enough length to allow for flex when the motor torques up, and go directly from the battery's earth, (so you have 2 earths).
OR
Do both
Bucky
486792
Reply By: Steve D1 - Saturday, May 26, 2012 at 06:29
assuming GQ series, combination switch for sure.... very common. Sold hundereds
Steve
486794
