bit of noise in hj 80 gear box
Submitted: Monday, May 28, 2012 at 20:42
RL boys
I have a hj 80 manual gearbox on a 93 glx non turbo 1hz
done a gen 270,000km
gear box is a bit noisey bit hard to change down from 2nd to 1st
noise in all gears doesnt jump out of gear ( not a whine just a bit of a slight rattle )
bit of back lash in drive chain
local 4wd mech recons not too much to worry about ,however dont want to get stuck
cruiser hasnt done much off road towed a horse float for a while before i had it
engine runs fine bit of black smoke ,doesnt burn or leak oil
any thoughts or experince cant find much in archives and some links not working
thoughts appreciated
thanks
Rob
Reply By: desray (WA - Monday, May 28, 2012 at 21:04
Have a look on
http://www.lcool.org/ lots of info on Landcruisers, not been funny the car is almost 20 years old, 270000 ks its entitled to whine a bit.
487044
Follow Up By: RL boys - Monday, May 28, 2012 at 21:25
thanks for that will have a look,
yeah my 12 yr old whines a bit ,
just hear some say the can be reraced and still whine
762283
Reply By: get outmore - Tuesday, May 29, 2012 at 03:31
Nothing to worry about - those old cruiser boxes get pretty tired, cant change without double clutching jump out of gear etc etc but they just keep going
487064
Follow Up By: RL boys - Tuesday, May 29, 2012 at 06:39
ah sounds like it got a bit more go in it then , as not to that stage
thanks
762306
Reply By: tonysmc - Tuesday, May 29, 2012 at 09:39
Rob,
Disconnect speedo cable and go for a drive. You would be surprised at the noise they can produce. I have known of people that have rebuild the gearbox and replaced wheel bearings only to find out its the cable, so its worth a first look.
Cheers tony.
487077
Follow Up By: get outmore - Tuesday, May 29, 2012 at 18:04
They dont have one
762362
Reply By: Member - Rodney B- Tuesday, May 29, 2012 at 09:48
Miy 97 model with a 4.5 petrol has done 237000 and has the same problem , a bit whiney in second and a fair bit of backlash, (mind you it has had the backlash since I bought it at 118000) hard to get from 2nd to third but you get used to it.
I wouldn't worry about it too much as these boxes are reliable and take a lot of punishment. All the diesels seem to have that rattle on idle.
I think your mechanic is correct.
Cheers Rod
487079
Reply By: ross - Tuesday, May 29, 2012 at 17:55
Sounds like its dying a little bit everywhere. The synchroes generally go in these(I think its the H150 gearbox)
I would start getting prices on a rebuild.Get yours rebuilt rather that accept a changeover.
487110
