charging laptop batteries
Submitted: Thursday, May 31, 2012 at 12:05
Member - questoz
We'd like to make use of the Hema maps we have downloaded to our laptop whilst travelling and hope somebody with personal experience could let us know the best way to keep the laptop battery charged.
Are there any cigarette lighter adaptors that will do the job without affecting or harming the computer - such as fluctuations in the power whilst driving? Or would the power from solar panels do the job - a lesser options as they are used mainly for keeping the car batteries charged for other uses.
Any help would be greatly appreciated.
Reply By: IronMan - Thursday, May 31, 2012 at 12:10
What about one of those can invertors? Plug into your power socket, then the 240v on the lappy transformer into the invertor. Power the lappy off it's battery as designed, little chance of damage there.
487259
Reply By: wombat100 - Thursday, May 31, 2012 at 12:20
I purchased a cig. lighter adaptor from Jaycar ($35)- for just that job !!
487260
Reply By: Geoff in SA - Thursday, May 31, 2012 at 12:24
Hi Questoz
the can convertors will do the job quite
But this will depend on the laptop size as some of the power supplies do draw the rated capacity of the cans.
There is another option available that is a specific laptop charger designed to operate from a ciggy socket. It is able to be set up with the specific charging voltage and has the different plugs to fit each laptop.
Available for Jaycar if I recall.
I have a smaller EE Book laptop I use and it has a very small charging requirement
So I use the can Inverter.
Geoff
487263
Reply By: Member - willawa - Thursday, May 31, 2012 at 13:00
Hi Questoz
Jaycar have just what your looking for ,multi plug,multi volt unit that pugs into your cigaret lighter. About 30 bucks.
Ed
487269
Reply By: Ron N - Thursday, May 31, 2012 at 13:06
Questoz - I got my 19V Toshiba car adaptor for my laptop off eBay, for $18 delivered. It works just fine.
I've got little doubt it's the same unit as the shops sell for $30, and I didn't have to drive anywhere to get it!
http://www.ebay.com.au/itm/320656226440
Cheers - Ron.
487271
Reply By: MEMBER - Darian, SA - Thursday, May 31, 2012 at 14:47
Yep - as said, the thing of it is that your Laptop is probably running on 19V DC - why run the car's 12V up to 240V via an inverter ($$) and then back down again through your laptop's charger ? The DC to DC chargers at Dick Smiths and Jaycar etc. are great, in that you can dial a variety of output voltages (may suit other appliances you have) ......and they have various end plugs that can be used to suit various jack sizes (again, may suit other appliances you have) - a great solution IMV.
487277
Reply By: Ross M - Thursday, May 31, 2012 at 15:34
Any cheap can inverter is only a modified square wave and many laptops DO NOT start up from this non sine wave, although some do.
If it doesn't it will most likely burn out the laptop power supply as it will be in a state of full on switching one way and can't detect the opposite sine signal to begin running.
Found this on my Toshiba, no go on modified square wave and runs perfectly on full sine wave.
Best/economical use of your 12vdc supply is to use a 12vdc to 19v, or whatever voltage it needs, from jaycar as already mentioned. Small, efficient, once only, power stepup to required voltage dc.
If getting solar:
The power from solar panels would still have to be regulated at the correct Laptop voltage. Better to use some solar to supply a regulated voltage charge to the car batteries.
487280
Reply By: Member - Bruce C (NSW) - Thursday, May 31, 2012 at 18:25
Reply By: Member - questoz - Thursday, May 31, 2012 at 20:40
Thanks to all of you for your quick responses and the very helpful suggestions. Obviously the first thing to do for my husband is a trip to Jaycar.
Cheers.
487310
Reply By: Member - Richard W (NSW) - Friday, Jun 01, 2012 at 07:30
Questoz,
Purchased a Dell 12v socket adaptor with the laptop when I bought it.
Now has about 100,000KM of use without a fault.
487338
Follow Up By: Geoff in SA - Friday, Jun 01, 2012 at 09:02
Questoz
Thats pretty good
what does that make it in kms per watt
Just the usual oil change every 100 Kw hour?
Only issue I see is the wear and tear on the lappy plug
lol
Geoff
762587
