1HZ oil pressure relief valve
Submitted: Wednesday, Jun 06, 2012 at 17:41
Changer
Hi folks,
I have an oil leak from my oil pressure relief valve (1HZ) and thought I may as
well replace the whole thing while I'm doing the gasket. I had. O troubles removing the plug and spring but can't get (or even see) the valve itself.
If anyone has done this before it would be great to hear how you got it out!
Charlie
Reply By: Ron N - Wednesday, Jun 06, 2012 at 19:31
Changer, I've always found a pair of long-reach external circlip pliers, slid up inside the hollow of the valve, and then expanded to grip the tubing of the valve, works for me.
Cheers - Ron.
487811
Follow Up By: Changer - Wednesday, Jun 06, 2012 at 19:57
Thanks for your advice Ron,
Ill give it a go.
Changer
763059
Reply By: Member - Toyocrusa (NSW) - Wednesday, Jun 06, 2012 at 19:56
If it wont come out easily I would leave it. It may have a carbon build up at the top end of it. If you get it down part way and it jams you may cause more problems than it's worth. Cheers, Bob.
487814
Follow Up By: Member - DOZER- Wednesday, Jun 06, 2012 at 20:55
Undo the cap, take tyhe spring out, then do the cap up b4 starting the motor for a few seconds only. When you undo, the poppet will be against the cap
763063
Follow Up By: Changer - Wednesday, Jun 06, 2012 at 21:29
Thanks for your help guys, I will let you know how I go!
763066
