Poptop Up or Down for Storage..?
Submitted: Thursday, Jun 07, 2012 at 10:12
Member - Oldbaz. NSW.
Sorry if this has been done before but I couldnt find a definitive answer..maybe there
isnt one...anyway ,what is your take on this ?, those that speak fluent caravan...
cheers....oldbaz.
Reply By: Wilgadene - Thursday, Jun 07, 2012 at 11:50
Hi Oldbaz,
I also was wondering which way to go and all the info I found is around 50/50 for up or down. I bought our van second hand so I wasn't sure as to how it was previously stored but after a few years of having it up in storage I found corrosion and pitting on the piston of the strut. It got bad enough to damage the strut seals and I replaced them. I do live about 6km from the coast so the salt air may have contributed. Anyway to cut a long story short I know keep the top down when not using the van for lengthy periods. So far so good. After a lot of wet weather the vynl may get a small amount of mould but cleans off easy and is a lot easier than replacing struts.
487844
Reply By: racinrob - Thursday, Jun 07, 2012 at 14:44
Baz. The builder of my custom made pop-top recommended leaving the top up while it was waiting for us to take it on a trip, reason he gave was so the rubber seal around the two sections were not compressed, that sounded reasonable to me.
I also live within a stones throw of the ocean, never had a problem with the piston rods on the gas struts rusting.
rr
487854
Reply By: briggzee (WA) - Thursday, Jun 07, 2012 at 16:24
Oldbaz, we have just purchased a new coromal poptop and the manual says to store the van with the roof down.
Hope this helps. Cheers. Briggzee
487861
Reply By: ozjohn0 - Thursday, Jun 07, 2012 at 16:42
Top up if stored undercover.
Top down if stored in he open.
OJ
487862
Follow Up By: disco driver - Thursday, Jun 07, 2012 at 20:01
That's what I have done for years, but I also have a couple of the windows open about 12mm (Half inch) to allow some circulation without rain etc getting in.
Disco.
763109
Reply By: Member - barry F (NSW) - Thursday, Jun 07, 2012 at 18:22
Howdy Oldbaz,
well as already said, more or less 50/50!! Opinions a bit like backsides I reckon, everyone has one!LOL
Anyway, my two bobs worth, we used to have a Pop Top & originally we stored it in the down position & covered it with one of those breathable caravan covers. Most occasions this was OK, but on one occasion after it had been stored for about six months or so we discovered it was badly covered in mould both internal & externally. The mould came off OK with a bit, actually a lot, of elbow grease, and all was unky dory again.
But from that point forward we always stored it in the up position & never had the mould problem, nor did we have any problem with rust/seals on the struts. Some people worry about the stress on the struts in the up position, but the lift up mechanism on ours (Jayco) relieved the weight from the struts, so no problem there.
Mind you the area we stored it had a southern aspect & was subject to mostly shade & for the most part did not receive a much sun. If you are concerned about mould the best bet is to check it fairly often as mould will come off pretty easy if it has not been there very long. Cheers
487869
