loading saved tracks from a magellon to gallexy running oziexplorer.
Submitted: Wednesday, Jul 25, 2012 at 00:22
ThreadID: 97070 Views:2631 Replies:3 FollowUps:6
Anyone know if it is possible to copy and paste all my saved waypoints tracks etc from a magellon explorist to a gallexy tab running oziexplorer.Magellon format is .wpt and .plt but accepts .gpx from memory.
cheers Graeme.
Reply By: Member - wicket - Wednesday, Jul 25, 2012 at 09:54
You will need a copy of VantagePoint and then use the import/export function.
AnswerID: 491620
Follow Up By: Member - wicket - Wednesday, Jul 25, 2012 at 09:58
Note.....VantagePoint only works with Windows OS.
FollowupID: 767129
Follow Up By: The Explorer - Wednesday, Jul 25, 2012 at 09:59
But not XP :(
FollowupID: 767130
Follow Up By: Member - wicket - Wednesday, Jul 25, 2012 at 10:41
according to the user guide (+win7)
Image Could Not Be Found
FollowupID: 767134
Follow Up By: The Explorer - Wednesday, Jul 25, 2012 at 17:09
Sorry - my comments were based on personal experience and not what was written in the user manual. Further research indicates that others have had trouble with XP but it is a problem (or variety of problems) that can be solved...at least in some circumstances.
I had several problems ranging from the program not even starting (current issue) to it not communicating with the GPS despite the program running. I just tried reinstalling the program then and it still won’t run.
Doesn’t matter anyway - I solved all of the problems in one hit - I dont bother to use Magellan units anymore (for the time being :)
Vantage Point uses GPSBabel anyway so I stick with my suggestion to use this. In the long term I would recommend getting the PC version of OziExplorer if using the Android version anyway. This will communicate with eXplorists fine and fast track the conversion (of data) process.
FollowupID: 767176
Reply By: The Explorer - Wednesday, Jul 25, 2012 at 10:09
Hello
Yes very possible. What program are you currently using to manage all your waypoints and tracks? I am assuming you have an older eXplorist based on the file formats your mention.
You just need to convert your data to GPX. This can be done with PC version of OziExplorer, VantagePoint, Mapsend Lite...or GPSBabel (plus a few other free and not so free programs)
Maybe GPSBabel is you best chance (in the absence of any other info on what you already have at your disposal) - Do a internet search and download it. It is a simple program that lets you convert one format (e.g. Magellan wpt) to another (GPX).
AnswerID: 491622
Follow Up By: Member - graeme W (WA) - Wednesday, Jul 25, 2012 at 21:19
Hi Greg.
Use map send lite and just paste and copy from explorist to computer.Read that oziexplorer used same. wpt. Plt.
Cheers Graeme.
FollowupID: 767202
Follow Up By: The Explorer - Wednesday, Jul 25, 2012 at 21:59
Hi Graeme
Unfortunately not that simple - the file extentions are the same but the formats are different. You will need to convert Magellan format wpt/plt files to OziExplorer format wpt/plt...one way or another.
FollowupID: 767211
Reply By: HGMonaro - Wednesday, Jul 25, 2012 at 18:38
I don't know if it will do what you want (never tried to) but I find this program very handy
AnswerID: 491668
