water in 100 series
Submitted: Sunday, Aug 05, 2012 at 20:24
ThreadID: 97279 Views:2574 Replies:7 FollowUps:2
just pulled draws out of the back of my 100 series standard.
pulled mat up very wet under, rear door seals good have done the hose test on them any ideas
Reply By: Witi Repartee - Sunday, Aug 05, 2012 at 20:28
I detest wet draws...I always keep mine in a water proof drawer.
AnswerID: 492325
Reply By: pop2jocem - Sunday, Aug 05, 2012 at 20:49
A couple of rust holes in the floor of my old banger seems to work a treat.....the water comes in...the water drains out. Have you been doing any creek crossings?? May be coming up through the floor. Just a thought.
Pop
AnswerID: 492328
Reply By: Member - Des Lexic - Sunday, Aug 05, 2012 at 21:02
Have you taken out the rear seats and not replaced the bolts into the floor. Maybe the water is getting in there. Only other suggestion is to take out the carpets and look for missing rubber plugs or other holes.
Des
AnswerID: 492331
Reply By: Jeff :) - Monday, Aug 06, 2012 at 01:18
Have you checked your aircon condensor drip tube? If the grommets are not seated properly or the hose/tube has problems the resultant moisture can travel along and wind up back inside at the next convenient point.
Just a thought.
Jeff
AnswerID: 492345
Follow Up By: BJ & Reen- Monday, Aug 06, 2012 at 07:31
I reckon ur right Jeff a lot of the 100 series have a second air in the rear when ordering draws u must let them know so as to build them accordingly
BJ
FollowupID: 768005
Reply By: Member - Rob K (VIC) - Monday, Aug 06, 2012 at 10:02
Hi wr450tractor,
A few of possibilities come to mind.
Agree with bolts holes not sealed in the floor but would only be an issue if you've been doing deep water crossings as they're fairly high up? Worth checking though.
Have you checked your rear quarter panel areas (behind the plastic moulding).Water can actually get into both rear quarter panels via the outside air vents just below the rear windows when you're washing the car. If the water can't get out via the drainage points in the bottom it might eventually fill and spill over into the rear compartment - although I would expect you should hear the sloshing water if it's that high;
Also, have you checked the window seals around the glass for the back windows? Are they still tight and seal properly? The glass can blow out a bit if you pressurise the cabin and then let water in past the glass;
You didn't indicate how old the 100 series was and even though you've checked the barn door seals, they could be getting worn and with the flexing letting water in during a trip.
My last suggestion is the check the Toyota forum LCOOL.org and see if anything comes up there - free registration.
Good luck with solving your leak.
AnswerID: 492358
Follow Up By: wr450tractor - Monday, Aug 06, 2012 at 19:34
He Rob
checked all that found RHS rear quarter panel full of mud drain holes blocked
everything else looks ok
cheers george
FollowupID: 768074
Reply By: DjohnW - Wednesday, Aug 08, 2012 at 10:03
Hi George,
I had exactly the same problem and the issue was eventually solved by proper resealing of my roof rack mounting bolt points !!!
djw
AnswerID: 492527
Reply By: Member -Toonfish - Wednesday, Aug 08, 2012 at 22:43
Dont forget to silastic the roof rack bolts as they can ingest water that pools down to the inside rear in the cavity obove the towbar mounts.
2013/14 around oz adventure bound
AnswerID: 492567
