air flow sensor
Submitted: Wednesday, Jan 14, 2004 at 11:17
ThreadID: 9731 Views:1672 Replies:10 FollowUps:2
G'day all, where exactly does the air flow sensor sit, and what does it look like on the nissan 3ltr td, just had mine replaced, but want to be sure there are new parts showing or finger marks of where they worked, not that i would distrust nissan, now would we, or am i being overly distrusting, even though i does run great now; regards, Adrian.
Reply By: Member - Terry- Wednesday, Jan 14, 2004 at 11:27
air flow sensor is located just up from the lid of the air filter.
Terry
AnswerID: 42911
Reply By: adrian- Wednesday, Jan 14, 2004 at 12:20
thanks Terry.
AnswerID: 42923
Reply By: howesy - Wednesday, Jan 14, 2004 at 14:50
air leaks in between your sensor and the inlet manifold on any vehicle can affect the running of the vehicle as there is unmetered air going in and the computer chucks a spaz.
Just something to keep in mind to check if the beast is ever playing silly buggers.
AnswerID: 42946
Reply By: adrian- Wednesday, Jan 14, 2004 at 15:16
ta, Howsey
AnswerID: 42948
Reply By: adrian- Wednesday, Jan 14, 2004 at 15:18
SORRY, Howesy
AnswerID: 42949
Reply By: Michael - Wednesday, Jan 14, 2004 at 16:15
Hi adrian,, what did it cost for the diaganosis and the parts and alabour, if you dont mind me asking Thanks and regards Michael
AnswerID: 42961
Reply By: adrian- Wednesday, Jan 14, 2004 at 16:41
Michael, I had it done under an extended warranty,the nissan dealler originally quoted approx 2 and a half hours of testing to be able to send the info to nissan techs at approx $60 .00 p/h total cost i have no idea, Truckster has made comment of around $1300 big ones, seems bloody expensive for what it is, suggest you ring nissan, regards, Adrian.
AnswerID: 42968
Follow Up By: Truckster (Vic) - Wednesday, Jan 14, 2004 at 16:46
Roly just had his 3rd or 4th one fitted.
FollowupID: 305258
Reply By: Truckster (Vic) - Wednesday, Jan 14, 2004 at 16:46
"where exactly does the air flow sensor sit, "
Usually in the garbage bin!
AnswerID: 42970
Reply By: adrian- Wednesday, Jan 14, 2004 at 17:14
Question, if the air flow sensor sends the information to the ecu uinit and the fitting of a Dtronic chip negates the need for the ecu ( or so i'm told ) does the Dtronic chip still rely on the info from the sensor or will it determine it's own need???????
AnswerID: 42979
Follow Up By: Leroy - Wednesday, Jan 14, 2004 at 23:30
The dtronic is a replacement ecu and will use the airflow sensor.
Leroy
FollowupID: 305333
Reply By: Member - Adrian - Friday, Jan 16, 2004 at 09:36
thanks Leroy.
AnswerID: 43207
