Monday, Aug 13, 2012 at 18:43
I did my '05 HZJ105 a few months back and I'm very happy with it.
We've recently done 7241 ks in 3 weeks towing a Jayco swan camper van with enough winter gear for 3 adults and 3 kids, fridge full, both
fuel tanks full, gross weight a little under 5 tons.
I hadn't taken the swan far, never with as many people/gear on an extended trip so I have no idea how it would be on
fuel pre turbo, on short trips I did It seemed pretty bad, but no real numbers to work with.
Fuel economy?, when pushed with cross winds, head winds, at freeway speeds, it was around 17-18 liters/100 ks, backed off to 85/90 kph and the it dropped to about mid 14's.
Its never used so much, but as sated, I haven't towed the van any real distance so i cant really judge, It did come very clear that by backing off a bit saved heaps in
fuel
Performance?, It hold the hills as good if not marginally better now loaded up with c/van on the back, then it did before hand with just me in it pre turbo.
With just me and nothing in the back, it goes real
well, still not suited for the traffic light drags but when it comes to a
hill, it just knuckles down, that's torque, that's what I've gained the most, that's what gets it up the hills.
Running around Urban
Brisbane as a work hack and school runner, with little freeway time its using 13-14/ 100ks, marginally better than before, but driven conservatively (real hard to do now), if you want to play you will pay at the pump.
I got little change out of $6K, but instal included full dyno, new injectors, pump timing, filters, full 3 inch
beaudesert exhaust, valve shims adjustments, basically a bloody good tune, which is what it really needed.
I've had to adjust my driving to suit, no more having the put the foot to the floor from second gear up, just needs a gentle touch now, Its been set up for power and will over
fuel making lots of black smoke when not in boost, but once IN boost, different story.
Image Could Not Be Found
Turbo begins to spool at 1000 rpm, full boost at 1800 rpm (also peak torque),
Its has lots of lag the lower in the rev range, but has virtually nil lag once above 2000 rpm, put the foot down and goes straight away.
Shane
492832
Follow Up By: Member - Shane D (QLD) - Monday, Aug 13, 2012 at 18:46
Sorry if you get a sore neck looking at that' side on.
768452
Follow Up By: harry j - Monday, Aug 13, 2012 at 19:53
thanks for the post,
I am quite amazed at how much 25% power increase can affect the truck from struggling to keep up with busses to being in the fast lane. why did you go 3 inch over the 2.5 exhaust that comes in the kit? i was assuming that they would be putting these kits out with enough flow from 2.5inch to more than handle the turbo.
768461
Follow Up By: Member - Shane D (QLD) - Wednesday, Aug 15, 2012 at 18:00
I was sort of up sized to a 3 inch when I dropped the vehicle off, it added $400 to the installation, the specialist made it clear that the 2.5 inch system was adequate but the difference being that I would get better throttle response and better heat dissipation from the turbo with a bigger system, only marginal gains in power if any at all.
One other thing and this is important, The 3 inch gave the cruiser a deeper note out the back, not louder, just. . . . . ., um . . . . . . . more MANLY, there, I said it.
I was talked out of spending $$$ on EGT's and boost gauges by the specialist, He told me the only gauge I needed to be focused on was the
water temp gauge, the T28 Garett is
water cooled he also includes a low
water alarm as part of the installation, if the motor fails because of no coolant then so will the Turbo, as afr as temps goes, Turbo will only get hot if left at full throttle at low RPM's for extented periods, it also has an internal wastegate, it won't over boost
Also
Mine has been set at 10 psi boost.
768538
