Landcruiser rim offset
Submitted: Wednesday, Aug 22, 2012 at 16:46
Lyn W3
Have a 2002 100 series which currently has a set of 16 x 8 ROH mag
wheels with 305 75 x 16 Coopers on it. The rims appear to have a 0 offset. I am looking to get an additional set of rims and run some 285 x 75 AT tyres and have found on various web sites that the rims should have a +60 offset.
Which is correct. Will a +60 offset cause the tyre to rub on the inside guard.
Lynn
Reply By: rumpig - Wednesday, Aug 22, 2012 at 17:18
depending on which variety of Landcruiser you own depends on what the wheel offset will be. from memory the live axels have a zero offset, and IFS models run a +60 offset. happy to be corrected if i'm wrong on that, but that's the way i remember it being.
493407
Reply By: Barry 2 - Wednesday, Aug 22, 2012 at 17:50
Hi Lyn
As Rumpig said if you have a live/solid front axle the offset is zero.
I am currently running the same rims on my 79 series Landcruiser Tray.
Barry
493410
Reply By: Barry 2 - Wednesday, Aug 22, 2012 at 17:54
Lynn
Forgot to mention that the rims I have are off a 2002 100 series I previously owned.
I have 265/75R16 Coopers on the rims.
Hope this helps
Barry.
493412
Reply By: Lyn W3 - Wednesday, Aug 22, 2012 at 19:15
Thanks,
Yes it ids a solid front axle so the 0 offset appears to be correct.
Thanks again
493419
Follow Up By: Crackles - Wednesday, Aug 22, 2012 at 19:25
For further reference Lyn you actually own a 105 series not a 100.
Cheers Craig............
769002
