fuel stops cairns to weipa
Submitted: Sunday, Aug 26, 2012 at 19:52
mark4
Hi all, can any one kindly tell me what is the longest distance is between
fuel stops from
cairns to
Weipa.
Also is there any where u can get auto gas from north of
cairns.
Thanks in advance
Reply By: Stretchlizard2 - Sunday, Aug 26, 2012 at 19:56
Mark
It depends on the
fuel you use.
493668
Follow Up By: mark4 - Sunday, Aug 26, 2012 at 20:05
sorry forgot to mention that i have duel
fuel gas & petrol, 75 litres petrol and 80 litres gas just wondering if i would have enough petrol to get from one
fuel station to another. gu patrol 4.litre
thanks
769273
Reply By: Stretchlizard2 - Sunday, Aug 26, 2012 at 20:42
Mark
Suggest you leave your gas bottle at home as there is none. The longest distance without
fuel is about 200k so no problems getting there and back.
Strongly suggest you get Ron Moon's book
Cape York and the Hema Map of the same. Between the two they will answer most of your questions.
Enjoy the planning and get your trip in before they make it blacktop all the way to
Weipa.
Cheers Stretchlizard
493671
Reply By: Member - Bucky - Tuesday, Aug 28, 2012 at 07:32
mark4
Do not worry about
fuel on the Cape.
Longest distance is out to
Weipa, not too sure of the K's but 200 would pull it up.
Do not use your gas, just keep it as insurance and only use it when you get bcak to
Cairns area.
Also think about this !
Keep topping up your petrol
tank tank
If you decide to have a crack at The Old Tele Track, and the
Creek Crossings, then empty 80 lt
tank under your mighty nissan will act like a float, and may cause you to loose traction.
Bucky
493765
Follow Up By: Member - Bucky - Tuesday, Aug 28, 2012 at 07:33
Sorry about that
had a "
Grey moment"
769384
