auto cable sizes
Submitted: Friday, Aug 31, 2012 at 21:27
ThreadID: 97772 Views:3288 Replies:6 FollowUps:2
best size cable for battery
Reply By: graham B9 - Friday, Aug 31, 2012 at 22:58
To do what?????????????????????????????????? To be more specific.
AnswerID: 494047
Reply By: olcoolone - Saturday, Sep 01, 2012 at 09:07
As big as possible.
AnswerID: 494055
Reply By: Tim HJ61 (WA) - Saturday, Sep 01, 2012 at 12:19
I find cable that measures 1mm across including the insulation is good to connect a battery.
With a cable this size I can run a torchlight all night without any problems with a cable about a metre long.
But I find when I have a big long 30 metre length of 1mm cable running into the tent, the light at the end is really dim. I wonder what is happening?
Then I thought I'd really give the 1mm cable a good workout and hooked up my mates NZ70 600CCA battery and jump started the diesel engine. OMG, there was a lot of smoke for a short time and I've destroyed my favourite cable. Oh dear. It's melted.
See Darryl R2 - thickness and length and knowing what you're trying to power make an awful lot of difference. Learning about Amps, Volts, Current, Voltage drop, cable length and resistance is fun, bit of a learning curve, but fun, and kinda important so you can use your torch or jump start your diesel.
Tim
AnswerID: 494067
Follow Up By: olcoolone - Saturday, Sep 01, 2012 at 14:19
Your answer is to looooooooooong for a short question....... I think he was asking about 1.5v AA's.
FollowupID: 769719
Reply By: Member - nick b - Saturday, Sep 01, 2012 at 17:17
Darryl ; I think you need to ask the question again with a lot more detail of what you want to do .......a lot of drunken sailor talk going on .... LOL
AnswerID: 494076
Follow Up By: Member - Peter R (QLD) - Sunday, Sep 02, 2012 at 18:50
6 B&S would be my suggestion.
Pedro
FollowupID: 769777
Reply By: Member - lyndon NT - Sunday, Sep 02, 2012 at 10:58
200mm Squared works well for me, bit heavy and costs a bit but not much voltage drop. :-)
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 494111
Reply By: Member - Alastair D (NSW) - Sunday, Sep 02, 2012 at 17:48
Darryl,
Tycab is an Australian company who make great products and know their business. I have used their products many times but have no affiliation whatsoever.
Follow the link and download their cable brochure. It lists the specs for more cables than you are likely to ever want. If you know what you are about then the brochure will give the answer. If you don't then go talk to an auto electrician so you get good advice.
Tycab
AnswerID: 494134
