80 Series Bash Plate
Submitted: Friday, Sep 07, 2012 at 07:07
ThreadID: 97876 Views:4221 Replies:1 FollowUps:3
Hello All,
I am wondering if anyone has made or knows a Company that has made a 'Complete Bash Plate' that would go from my ARB Bullbar right through to my gearbox as either one piece or two sections
This would then protect my radiator (anything coming up from under neath into the radiator), protect my steering assy, engine sump through to gearbox /transfer box - as well as allowing oils to be drained without taking plate off
Any advice will be greatly appreciated
Thanks,
Chris
Reply By: Member - Tony V (NSW) - Friday, Sep 07, 2012 at 10:13
Chris,
I am not sure if you have checked with ARB, TJM and Opposite Loack who all produce under body protection.
I have TJM guards on my 100 series. it does not have holes to enable oils to be drained, I believe that it is important to remove these plates the get rid of any mud, sand and debris that collects in between services. It also means you can check or leaks etc.
There are a number of small specialist under-body protection companies but Google is possibly best for that, or a smaller sheet metal work place.
Good luck.
AnswerID: 494401
Follow Up By: Member - Chris B5 - Friday, Sep 07, 2012 at 10:57
Hi Tony,
Yes discussed with ARB, TJM etc but they only have little gearbox protection plates
I have googled every where, but it seems the 80 series is the only one that Co. do not make full plates for
Tried our small specialist under-body protection companies here, but they all seem to think all too hard
Thanks for the follow up anyway
Chris
FollowupID: 770076
Follow Up By: Member - Tony V (NSW) - Friday, Sep 07, 2012 at 15:31
Talk to Bush Skinz in NSW They make bash plates or under body protection plates for many vehicles and although they do not show an *0 it is worth asking them.
OR
Try Macquarie 4X4 They also produce theseitems and I am sure still have an 80 template.
FollowupID: 770090
Follow Up By: Member - wicket - Friday, Sep 07, 2012 at 16:26
http://www.underguards.com.au/ (brown davis )
FollowupID: 770093
