What works best
Submitted: Friday, Sep 07, 2012 at 21:54
ThreadID: 97893 Views:2761 Replies:9 FollowUps:10
What have you found that works best of getting gaffer tape glue of a aluminium bull bar?
Reply By: The Explorer - Friday, Sep 07, 2012 at 22:00
Petrol.
AnswerID: 494457
Reply By: Allan B (Member, SunCoast) - Friday, Sep 07, 2012 at 22:00
The glue of tapes, including gaffer, are usually easily removed with turps.... unless the glue has hardened sand dried. Even then, turps can still be used by wrapping the dried glue with strips of cloth soaked in turps and allowing to soak for several hours. Some gentle scraping may be required.
AnswerID: 494458
Follow Up By: Allan B (Member, SunCoast) - Friday, Sep 07, 2012 at 22:02
Correction...... "and dried" not "sand dried" Doh!
FollowupID: 770125
Reply By: desray (WA - Friday, Sep 07, 2012 at 22:09
crc,,, wd40 melts the glue,wipes off .
AnswerID: 494459
Reply By: ben_gv3 - Friday, Sep 07, 2012 at 22:19
Eucalyptus oil...plus it will clear your sinus.
AnswerID: 494462
Follow Up By: Member - Bruce C (NSW) - Saturday, Sep 08, 2012 at 15:58
Another vote for Double D eucalyptus oil. Dearer than turps or petrol but smells a whole lot better.
FollowupID: 770150
Reply By: firm351 - Saturday, Sep 08, 2012 at 09:30
Aerogard works a treat
AnswerID: 494478
Follow Up By: Member - Josh- Saturday, Sep 08, 2012 at 17:41
We use aerosol to remove graffitti as well.
Josh
FollowupID: 770154
Follow Up By: desray (WA - Sunday, Sep 09, 2012 at 04:32
Aerogard , strange stuff that ,I have seen several shires use it to remove graffiti from windows ect. And we spray it on our skin????
FollowupID: 770177
Follow Up By: Allan B (Member, SunCoast) - Sunday, Sep 09, 2012 at 08:12
Yep, it works a treat getting graffiti off skin.
FollowupID: 770186
Follow Up By: Member - Josh- Sunday, Sep 09, 2012 at 09:12
Hahahahahahaha
FollowupID: 770191
Reply By: Shaker - Saturday, Sep 08, 2012 at 16:32
Prepsol.
AnswerID: 494501
Follow Up By: Gone Bush (WA) - Saturday, Sep 08, 2012 at 18:13
+2
FollowupID: 770156
Reply By: graham B9 - Saturday, Sep 08, 2012 at 19:35
Goof Off
http://www.ebay.com/itm/4-5oz-Goof-Off-Dried-Paint-Remover-also-ink-magic-marker-crayon-NEW-FG650-/390419282406
See link above.
I descovered this when I moved to the USA. Now available in Australia but I had not heard of it before. I was suspicious at first but everyone here answers the same when you ask for a remover.
Make sure you use gloves however as it also removes the oil from your skin as well as everything else.
AnswerID: 494513
Follow Up By: graham B9 - Saturday, Sep 08, 2012 at 19:37
Cobber also if you are taping things to the bull bar try using airconditioning duct tape. It is strong and comes off easier and does not dry out the glue as quick at gaffer tape.
Gaffer tape in the US is called Duck ( as in quack quack) tape.
FollowupID: 770160
Follow Up By: Allan B (Member, SunCoast) - Saturday, Sep 08, 2012 at 22:53
Graham,
Gaffer tape originated in the US and is called "Gaffer tape" as it is used by Gaffers (electricians) in the film industry. It is a fabric reinforced adhesive tape used for attaching lights etc to supports rather than electrical insulation. So Gaffer tape in the US is called just that.... Gaffer tape.
"Duct" (not Duck) tape is a PVC tape designed principally to connect and seal air-conditioning ductwork but often adapted to other uses.
FollowupID: 770174
Follow Up By: graham B9 - Sunday, Sep 09, 2012 at 08:15
thanks Alan.
I never knew that.
FollowupID: 770188
Reply By: Steve M1 (NSW) - Saturday, Sep 08, 2012 at 19:59
or "duct" tape
AnswerID: 494517
Reply By: cobber - Saturday, Sep 08, 2012 at 21:42
Thanks for the reply's much appreciated
AnswerID: 494522
