Cleaning fiberglass showers
Submitted: Friday, Sep 21, 2012 at 09:51
jimbo qld
What products do you recommend for cleaning the walls and base of the shower in the van.
Reply By: Member - wicket - Friday, Sep 21, 2012 at 10:14
If you have to ask this question then I'm guessing you use regular soap, if so stop using it.
Start using body wash and you will find that cleaning the shower is hardly necessary.
495338
Follow Up By: jimbo qld - Friday, Sep 21, 2012 at 16:38
Thank you wicket, that's a good idea..will go with liquid soap
771015
Reply By: Danna - Friday, Sep 21, 2012 at 11:33
Cheap tooth paste should do the job.
Dana
495345
Reply By: Member - DereelGirl - Friday, Sep 21, 2012 at 18:14
A citrus spray should do the trick, it also keeps the shine on the fibre glass.
R
495369
Reply By: margery l - Friday, Sep 21, 2012 at 18:14
Those white foam blocks that you can get from Bunnings or some supermarkets are fantastic! Don't know why the work but they will clean anything off surfaces like your shower
Cheers Margie
495370
Reply By: Member - Old Girl - Saturday, Sep 22, 2012 at 00:01
I use our car wash with the wax in. The
water beads off.
495392
Reply By: Danna - Saturday, Sep 22, 2012 at 01:52
When we bought our Decina bathtub, (it’s 1.9m long fibreglass/acrylic) we get
user guide. The manufacturer says: if you get stubborn stain even from
water residue, use fine car polish.
So there you go, you can at least try few things.
Cheers Dana
495395
Reply By: Pebble - Saturday, Sep 22, 2012 at 21:15
I believe that
water quality makes a bigger difference compared to using soap vs not using soap. Ever since we've lived on a property with a big rainwater
tank (filtered as
well) I have to clean the showers and bath tub (tiled with glass doors) far less often, and we mostly use soap, cheap kids bubble bath is best for in the bath, doesn't leave bath rings like some of the more fancy stuff.
At times I've thought some of the soap free stuff makes more mess, particularly if it has moisturising creams and what not in it.
To scrub the floors of fiberglass showers in the past I've used gumption, but I have found that domestos (even diluted in a spray bottle) works really
495437
