Solar Panels
Submitted: Sunday, Sep 30, 2012 at 08:14
Member - peter & dawn m (QLD)
I have are caravan with what i believe to be 3 x 80 watt solar panels mounted on the roof .I would like to mount an extra 2 x 100 or 120 watt solar panels BUT i have been told they would only supply the same amount of charge [or watts] as the smaller panels the next person of knolage tells me if you run them threw a regulator every thing will be all right ?? who right & who is wrong? any comment would be welcome. swampy
Reply By: Peter_n_Margaret - Sunday, Sep 30, 2012 at 09:25
What regulator are you using now?
OKA196 Motorhome
495923
Reply By: Member - Gethro - Sunday, Sep 30, 2012 at 11:54
Hi Peter,
Different capacity solar panels should all work okay together as long as they all feed
into a solar regulator that has ample capacity to handle the charge.
It is also important to run as heavy wiring as you possibly can to reduce voltage drop.
Also all the panels should run a blocking diode each to prevent reverse current back into the panels. I run 3 x 64 watt panels and have a 30 amp solar regulator which is more than required but also allows for any future expansion.
Regards,
Gethro
495933
Reply By: Member - peter & dawn m (QLD) - Tuesday, Oct 02, 2012 at 16:22
sorry to take so long to get back i can,t find a regulator only a pannel that shows you what the solar pannels are charging must be one hidden or in build in van. swampy
496051
Follow Up By: John E - Friday, Oct 05, 2012 at 22:54
hi , we just had a problem with the solar in our Baroma van , and the technician finally found the regulator BEHIND the panel , and not in a place that one would expect to find it , or be able to check it .cheers , lyn
771857
