Stuck in 3rd gear Ford Courier PE 2000 4x4 diesel
Submitted: Monday, Oct 08, 2012 at 15:48
workhorse
I noticed a whining coming from the gearbox only in 3rd gear only, none of the others for the past 10 days and today she just got stuck in 3rd.
Any suggestions and how easy/difficult a fix this is?
The ute is my everything vehicle and sole means of transport here on the farm so am stuck at home deciding what to do.
Any help appreciated.
Michael
Reply By: Mudripper - Monday, Oct 08, 2012 at 22:35
Hi Michael,
Well I'm no transmission expert, but it could possibly be-
1. Synchro hub assembly worn out
2. Selector fork/shaft broken
3. Worn bearings
4. Excessive shaft end float
You mention whining - how many km's on the clock? Might be up for a gearbox rebuild.
Maybe someone can provide more optimistic (or accurate!) information than me lol.
Tim.
496330
Follow Up By: workhorse - Monday, Oct 08, 2012 at 23:02
Thanks Tim
It has just done 200k Kim's. The whining only for the last 10 days. Happened so quickly
772030
Follow Up By: dbish - Tuesday, Oct 09, 2012 at 09:15
At 200Ks i would suspect bearings. Drain oil from box & check for metal & posibly bearing balls, most courier drain plugs had magnets on them. If you want long life out of a gearbox then regular oil changes are the order of the day. (my exp as as an X Ford mechanic in a country dealership) lots of farmers here have Couriers.
772045
Reply By: Member - Serendipity(WA) - Tuesday, Oct 09, 2012 at 10:13
My son's mazda bravo gear box did a similar thing. He managed to order a low kilometer jap import one from a wrecker in Queensland delivered to his door at half the price of a rebuild earlier this year. I will have to get back to you on where and who.
496346
Follow Up By: Member - Serendipity(WA) - Tuesday, Oct 09, 2012 at 10:27
I contacted my son.
http://www.gearboxengine.com.au/
The wreckers were pretty good to deal with. These are second hand low km imports. The first one sent had a whine so we sent it back at their expense and they posted another one, perfect condition. So unlucky we got a dud one but an honourable business to deal with.
Hope that helps.
Serendipity
772048
