fuel consumption yet again
Submitted: Saturday, Oct 13, 2012 at 19:03
Trev&Ness B
can people please give me an average
fuel consumption level between towing and around town on there 4.2turbo diesel engines, and also tell me what year and model off the car.
thanks
Reply By: Trev&Ness B - Saturday, Oct 13, 2012 at 19:05
sorry also weight of van etc.
496619
Follow Up By: baz&pud (Tassie) - Saturday, Oct 13, 2012 at 19:43
We have a petrol cruiser, and tow a nearly three ton van,
fuel consumption drops about 20% (average), but does vary depending on the terrain, and weather conditions.
Friend has a 4.2 diesel, and his is similar.
Hope this helps.
Baz
772324
Follow Up By: Trev&Ness B - Saturday, Oct 13, 2012 at 19:51
baz&pud
do you kniow the basic numbers per 100kms with and without van
772326
Follow Up By: baz&pud (Tassie) - Sunday, Oct 14, 2012 at 11:00
Trip just completed was 14000++, and we averaged 4.55 ks per litre, as far as around town i don't keep figures, as the cruiser is really only for pulling the van.
Back some 6 or 7 years ago when i did keep the it was about 6kpl, but take into account it was all short running around town.
We have now made the decision not to keep consumption figures because if we want to go somewhere, we are going to go, so bugger the cost .
772361
Reply By: Member - Ian W1 (QLD) - Saturday, Oct 13, 2012 at 19:41
I've got 4.2TDi 2004 manual Patrol. Around town about 14litres/100km..on a trip this can rise to about 16-17l/100km towing a 1200kg campertrailer on the blacktop sitting on 100kph or go to about whatever! when towing in low-range in rough country. You've asked a VERY open-ended question and I suspect the responses won't mean much as there are just so many variables eg laden weight of vehicle, what's on the roof, speed, terrain, what gear and range is being used etc etc. Good luck with getting something which will be anything more than a very rough guide. Cheers.
496623
Follow Up By: Trev&Ness B - Saturday, Oct 13, 2012 at 19:49
yeh i know the question has alot of varuables but im hopeing people will keep it simple. eg 2003 4.2td 12ltr around town, 17ltrs towing 2.5t camper at 100kms. Im not looking for exact numbers just a basic comparison between makes and models and years.
772325
Reply By: Member - kym111 - Saturday, Oct 13, 2012 at 20:17
We have a 2004/5 GU Patrol, 4.2td with gas injection. When on gas, we easily sat on 80-100kms/ph on a good gravel road recently, towing a 3 tonne 22' caravan.
On the way home the air filter choked up, we ran out of gas, had a horrendous side/head wind and at times could barely get to 65kms/phr. Hubby did say what the
fuel economy was (nothing flash!), but I can't remember the details. Something like 17ltr/100kms. May have been down to 14ltr/100kms on the good bits!
He's now considering a turbo upgrade to assist with more power, especially when we are unable to use gas due to lack of supply.
496625
Follow Up By: Member - Michael and Chris (QL - Sunday, Oct 14, 2012 at 07:27
Hi Kim111,
Based on what figures you provided, I wouldn't be too keen on changing anything on that engine. Those figures are very good results given you are towing a 3ton van. As far as the air filter getting clogged, it isn't hard to quickly clean the filter and put it back in.
772351
Follow Up By: Steve M1 (NSW) - Sunday, Oct 14, 2012 at 08:33
looking at those figures on straight diesel after the gas choked, they must've been going downhill all the way home.
772352
Follow Up By: Member - kym111 - Sunday, Oct 14, 2012 at 12:08
I stand very corrected... I just checked with hubby, on the way home we did 25ltr/100kms! Absolutely hideous!
As for the air filter, it should have been replaced before we hit the road. As it was, when it was discovered that it was clogged, a simple tap wasn't enough. Hubby cleaned the chunks of oily mud and dust out best he could (no spare....), cleaned it with petrol, let it dry and put it back in. I believe a new one went in the day after we got home...
772363
Reply By: Member - neville G (QLD) - Sunday, Oct 14, 2012 at 08:05
Hi Trev and Ness,
We have a 4.2L T/D Landcruiser (05) and tow a Phoenix caravan weighing around 3t. Around town, not towing, it averages 11lts/100 and towing between 17 and 20lts. per 100 depending on terain, wind etc. towing we travel at 90 to 100Klms. per hour, the towing figures are after 12000klms. which we have just completed.
Cheers, Bundy
496647
Reply By: Steve M1 (NSW) - Sunday, Oct 14, 2012 at 08:38
17l/100 towing 3 ton? gee there's a lot of dowhill driving with tail winds around here. Either that, or wishful thinking.
496649
Follow Up By: Steve M1 (NSW) - Sunday, Oct 14, 2012 at 09:12
having said that, at the end of a long day's towing, my tug provides me with a recling supermodel on the bonnet with a nice cold one in one hand and a lovely roast dinner in the other but I'm buggered if I could get 17/100 towing three ton on the dirt.
772356
Reply By: Member - Tony (ACT) - Sunday, Oct 14, 2012 at 09:04
98 4.2 GU with Turbo & intercooler. Around town unladen 12/100 towing 1750kg dual axle camper with boat on top of vehicle 16 - 17/100 at whatever speed I want. With no boat 15 - 16/100. Tow in 4th gear only.
496650
Follow Up By: bazz - Sunday, Oct 14, 2012 at 09:41
2ooo patrol ute /na, towing roadstar 2.1 ton, plus
water etc , 400ks on 90 litre
tank, 700 ks when not towing, slow but we get there, 30 thou kms in 10 months ... 193 thou on odometer, 1
water pump fixed myself, 1 alternater belt last weekend ( probably over tightned it) thinking about turboing ute...
772358
Reply By: Member - Bruce C (NSW) - Sunday, Oct 14, 2012 at 09:44
Hi Trev,
These are towing figures only.
80 series turbo diesel Cruiser towing 2 tonne van 17.5ltr/100K various terain but contains some driving over and along the Great Divide
2003 100 V8 petrol series Cruiser over similar teraim to above towing same van 22ltr/100K
Upgraded van now close to 2.5tonne now getting 22.75ltr/100K over similar terain.
This V8 petrol vehicle was 15 to 20 grand cheaper than a comparable 2003 turbo diesel 100 series.
Cheers, Bruce.
496655
Follow Up By: Steve M1 (NSW) - Sunday, Oct 14, 2012 at 14:28
if my maths are correct, that's roughly about 66,000ks of petrol saved by going petrol. Taking your lower figure of 15 grand cheaper and
fuel @ $1.50 doing a regular (not towing) 15L/100ks . So around three years or more average mileage/kilometerage "paid for". I have used diesels for a good few years now but it's a reasonable argument, as I'm sure Robin, in his 4.8 Pootrol would testify. That may be a conservative estimate but after 3 years the diesel would start to claw that back. The difference would diminish if we were talking used vehicles but whatever, it's an interesting one. All rough figures but it gives some perspective. One other thing I have found is that contrary to popular belief, I have spent no more on maintenence of my current Prado D4D (diesel) than a previous LC100 petrol.
772370
Follow Up By: Member - Bruce C (NSW) - Thursday, Oct 18, 2012 at 19:26
Hi Steve,
A mate bought a 2004 Sahara TD Cruiser for 60 grand about 12 months before I bought my 2003 GXL Petrol Cruiser which I paid 22.5 grand for.
As you can see I have been conservative with my figures concerning purchase price.
My consumption figures are acurate though.
Cheers, Bruce.
772664
Follow Up By: Steve M1 (NSW) - Thursday, Oct 18, 2012 at 20:12
yep - that price diff buys a lot of fuel Bruce. I'm doing a similar excercise with the Prado (previously also had a LC100 two cars back but not as much diff with the Prado) it's a very nice feeling on those long trips to fuel up with diesel knowing how far it has/will take you but you pay upfront for it. No simple answer that covers everybody but it's a close one these days. Diesel used to be
well below the cost of petrol but as soon as there's a market for it the barstards whack the price up.
772666
Follow Up By: Steve M1 (NSW) - Thursday, Oct 18, 2012 at 20:26
just an afterthought, I got rid of my petrol LC100 because of the fuel I was getting through but really, it's all relative and if you get a bit upset every time you need to fill up, just think of what you've saved at purchase. You can end up chasing your tail with this stuff and in the end, there's probably little in it. I can't honestly say one is better than the other on consumption but I have a leaning towards the diesel for other reasons. The same suit doesn't fit everybody though.
772669
Reply By: Member - Bucky - Sunday, Oct 14, 2012 at 09:46
7.5 km/lt around town
8.0 km/lt on the highway
Towing our camper... usually 5.5km/lt - 6.5 km/lt depending on head winds and road surfaces
But I don't care, I'm on holidays, when towinng
By the way
When we owned the 3.0 TD Navara,
I go 9.5 km/lt around town
10.5 km/lt on a trip
Towing the Camper... Same as the Patrol 5.5 km/lt - 6.5 km/lt
Have the Mighty 4.2 TD Partol any day
Cheers Bucky
496656
Reply By: Member - Shane D (QLD) - Sunday, Oct 14, 2012 at 20:10
I have turboed my NA 1HZ 1## series cruiser and can get around 12-13 liters /100ks empty and driven conservatively, when towing a Jayco swan (3 adults, 3 kids,a little under 5 ton gross) on recent 7500 k journey the economy varied greatly mainly due to driving speeds and relative winds,
Here are my feul records
I should point out that this history started with the camper on and doesn't really reflect its good side, my cruiser tends to be sensitive to weight and stuff on the roof rack, take away the weight and keep the roof rack clear and behave in stop start traffic and it can give reasonable results.
When comparing landcruiser Turbo diesels, ensure you find out if its either a factory turbo or an aftermarket turbo, big difference in technology and vehicle purchase price, but is reflected in its fuel economy.
Shane
496679
Reply By: honest - Monday, Oct 15, 2012 at 07:31
We have a 96 aftermarket turbo 4.2lt Patrol ute around town about 7.6 klm's per ltr towing 2 1/2 ton van at apprrox 90-95 klm's an hour about 5.5 klm's per litre.
cheers honest
496700
Reply By: Brian - Tuesday, Oct 16, 2012 at 01:22
i own an old Tojo Sahara 4 litre turbo diesel , went to the Kulin bush races ( WA ) recently , left
Australind with a full tank , drove at 80kph ( v slow ) towing an old 18ft Opal van , not sure of the weight but think its fairly heavy , was 306 ks to
campsite , then back to Kulin on the Sunday , totalling about 321 ks , to fill tank took 56.14 litres of diesel . I thought that was fairly heavy consumption . not wanting to hijack your thread mate but while everyone is on the subject thought i might get the odd comment or opinion .
496761
