2012 GU 8 rear door sag
Submitted: Saturday, Oct 13, 2012 at 21:37
ThreadID: 98524 Views:2216 Replies:3 FollowUps:1
Just wondering is it worth while getting a wheel carrier attached to my rear bar when i it or just leave the wheel attached to the barn door? Im a bit woried about the door sag, cracking and letting in dust. Does anyone have an opinion?
Reply By: Member - Bucky - Sunday, Oct 14, 2012 at 09:37
Rear door sag already !
We have a 2001 Patrol, and she has been in a lot of spots.
She has no rear door sag, and the tinyest of cracks happening.
Don't worry about it
Then if you must have a wheel carrier, then get one.
Bucky
AnswerID: 496654
Follow Up By: Michaeljp - Sunday, Oct 14, 2012 at 11:34
Mine doesn't sag yet. Just looking into the future if its a problem with this model or not.
FollowupID: 772362
Reply By: Grizzle - Monday, Oct 15, 2012 at 11:28
Had Patrols since 2000, no problem with door sag. I also carried a 25 litre water jerry on the wheel for 4 years with no problem. Only put the rear bar on because I wanted Dual wheel holder.
AnswerID: 496710
Reply By: Robin Miller - Monday, Oct 15, 2012 at 12:00
No real issue Michaeljp
There were a few earlier ones that had an issue - but I believe most were tracked down to be because of fitting heavier wheels or failing to keep them adjusted right so that they could move and knock.
We have 3 GU's and none have that issue , sealing was improved also years ago.
AnswerID: 496713
