A nifty gadget
Submitted: Monday, Oct 15, 2012 at 18:09
TheMightyMoose
Was recently given a "crochead" mozzie coil holder. Compact and effective, especially when you have bits of mozzie coil that have broken off and can't fit on the standard type holder. Check them out at crohead.com.au. No affiliation - just a happy camper passing on info for those that are interested.
Reply By: Member - Rod N (QLD) - Monday, Oct 15, 2012 at 18:59
Moose, You got the web site name wrong. Also how about using the "Insert Link" tab or copy and paste the URL so that it is easier for readers to use.
496727
Follow Up By: Member - Rod N (QLD) - Monday, Oct 15, 2012 at 19:01
BTW the site is
Crochead
772449
Follow Up By: Krooznalong - Tuesday, Oct 16, 2012 at 13:58
Thanks for posting the correction.
772495
Reply By: Member - OnYaBike - Monday, Oct 15, 2012 at 20:25
That's neat! I found if you stretch some of that woven fabric you use for fibreglassing on a frame, you can burn bits of mozzie coil. They won't burn through and they won't go out, as they do with metal mesh.
But this idea is so simple.
496735
Reply By: Amber G - Tuesday, Oct 16, 2012 at 11:14
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
496778
Reply By: member - mazcan - Tuesday, Oct 16, 2012 at 14:23
hi
yes its a good invention
but i just use a paper clip to hold the broken pieces while they burn away and the paper clip can be hung up or sat on an upturned baked bean tin
cost zilch
496791
