GPS power
Submitted: Monday, Oct 15, 2012 at 18:11
SDG
I'm getting my parents a GPS for christmas to go in there motorhome.
Their motorhome is 24volt. Some people have said that the power cord will be fine for a 24volt as it converts power down to recomended wattage, others have said it will blow it up?
Does anyone here know?
Has anyone got a 24volt vehicle that uses a GPS?
Last thing I want to do is blow up a new GPS.
Reply By: Chriscleo - Monday, Oct 15, 2012 at 18:21
They will need a 12 volt outlet for other things as
well, so run a couple off the house batteries for the GPS and others as needed. Some power cords will cope, some wont, it will be marked on the cord!
(I guess it is a coaster?)
496725
Follow Up By: Chriscleo - Monday, Oct 15, 2012 at 18:22
They can then use their phone charger on the road as
well!
772445
Follow Up By: SDG - Monday, Oct 15, 2012 at 21:55
Already have 12v outlets in the back. Trying to avoid a 6-7foot extension lead to the dash where the GPS would be used.
(isuzu base motorhome)
772461
Follow Up By: Chriscleo - Tuesday, Oct 16, 2012 at 10:51
A simple converter to change the 24volt to 12 volt is also available. these are not too big or expensive and will fit behind the dash. Try a twelve volt specialist or Jacar.
772487
Reply By: kev.h - Monday, Oct 15, 2012 at 20:34
Some have a 12v supply to run the dash /radio etc. so you may find a 12v supply otherwise you can get a 24 to 12 voltage regulator they handle about 6 amp and are quite cheap from Jaycar and others I guess probably also ebay alternately just run a supply from one battery
Cheers Kev
496736
Follow Up By: SDG - Monday, Oct 15, 2012 at 21:59
Going to Jayco tomorrow to see what they say.
I did suggest that they might need to convert the cig lighter to 12volt.
Everthing on the thing is 24volt. Dash, front and rear lights, radio, etc.
Reminds me of my first Patrol which was 24 as
well. Did not find that out till I blew up a stereo. Had to run seperate wiring for my accesories.
772464
Reply By: SCUBADOO - Tuesday, Oct 16, 2012 at 07:12
SDG
FWIW
I have 10 or so original Garmin DC ciigarette lighter type power adaptors here from various handhelds and vehicle nuvis.
They are ALL labeled "10-30 VDC".
Any Garmin nuvi GPS will run perfectly in your parents motorhome without modification to the supplied adaptor.
496763
Follow Up By: SDG - Tuesday, Oct 16, 2012 at 09:16
That is good to know. Thanks for that info.
I have a Nuvi myself, but as I don't have the original plug there was nothing written on it. Maybe the package it came in, but that is long gone.
772475
Reply By: Member - Doug P (VIC) - Tuesday, Oct 16, 2012 at 11:46
Hi SDG
My Tom Tom Car charger states 12/24v input 5v/2a output so should be no worries with Tom Tom GPS either
496779
