slideon camper tie down
Submitted: Saturday, Oct 20, 2012 at 21:09
mark m8
Hi, can anyone recalll how the early model slideon campers 1980s were tied down to holden and falcon wellback utes,as Im looking for a cheaper option than the torq lift and happy jac ones.
Reply By: Member - MUZBRY(Vic) - Saturday, Oct 20, 2012 at 21:30
Gday
With a hook and turnbuckle.
497034
Reply By: mark m8 - Sunday, Oct 21, 2012 at 08:13
g.day, I got that part just trying to work out a secure way to attach the chain to the ute like would a tie down point screwed through the panel do or do you need to attach to the chassie.
497051
Reply By: Member - Vince M (NSW) - Sunday, Oct 21, 2012 at 11:13
Mark
on a style sided ute, use to be 4 eye pads bolted thru ute body
fwd point was aft of slide ons fwd tie point & aft one was fwd of slide ons tie point on a tray back use to be chained to load rail Both use to come with 4 turn-buckle's with a lock nut (so they would pull towards & down of each other) you can use 4 cheap jockey
wheels but they have to be side winders & just extend them (weld pipe & bracket) but if you look around you will find some cheapys, I got a good set but had to buy a whole side on for $100 & $50 to dump at
the Tip
good luck
497064
Reply By: mark m8 - Monday, Oct 22, 2012 at 07:19
thanks Vince, the jockey
wheels are a good idea.
497116
