sattelite dish portable
Submitted: Sunday, Oct 21, 2012 at 15:37
ThreadID: 98658 Views:1867 Replies:3 FollowUps:3
hi any one with best ideas on brands etc cheers
ricbrad
Reply By: Member - Rod N (QLD) - Sunday, Oct 21, 2012 at 16:24
Try Satplus
AnswerID: 497077
Follow Up By: Member Andys Adventures - Sunday, Oct 21, 2012 at 19:54
Agree with Rod Satplus sells a min dish and works well.
Andy
FollowupID: 772832
Follow Up By: K&FT - Monday, Oct 22, 2012 at 10:43
Agree with Rod too, satplus gives great service and excellent backup.
depending on where you are travelling you may need an 85 cm dish to make finding the sat much easier and better rain performance.
frank
FollowupID: 772874
Reply By: auzinomad - Monday, Oct 22, 2012 at 00:12
A "found" Foxtel dish mounted on a flood light stand from Bummings is a lot cheaper than most suppliers.
If your lucky it still has the dual LNB on it, one dish for you and your mate next door, both screwed into the LNB.
If You cut the LNB arm off behind the dish and fit a sleeve , bolted one side and a thumb screw the other for sliding the arm back in, it will be a cinch to carry as well.
Ron
AnswerID: 497108
Reply By: ukwizard - Tuesday, Oct 23, 2012 at 00:22
I have a 'found' foxtel dish, and a spare digital setup box. Do I need any special subscription to get Free to Air TV? I have plenty of foxtel grade cable (RG6 I think) and will buy a sat finder (ebay etc). Anything to watch out for or any advice would be greatly appreciated.
AnswerID: 497192
Follow Up By: landseka - Tuesday, Oct 23, 2012 at 09:28
I hope by "spare digital setup box" you mean a Satellite Decoder?
If not then you will need to buy a VAST Decoder which is $269 pretty much wherever you choose to buy.
This box will come with a card which is all you need to "subscribe".
then you need sufficient cables, fittings, tripod, the correct LNB and the Sat Finder.
Get a good Sat Finder, Satplus have a perfectly adequate one for around $100.
Cheers Neil
FollowupID: 772969
