Uniden uh065sz
Submitted: Thursday, Oct 25, 2012 at 09:50
Paul N5
I have a pair of handheld uniden uh065sz and both have a BUSY signal that will not allow me to transmit or receive. Any suggestions?
Reply By: Member - Rob K (VIC) - Thursday, Oct 25, 2012 at 12:13
Hi Paul,
Check if the transmit button is stuck on either unit or alternatively, check your squelch level setting - might be set too low and picking up the general radio static. Set the squelch to a higher setting to cut out the background noise.
Rob K
497356
Reply By: MEMBER - Darian, SA - Thursday, Oct 25, 2012 at 15:20
Not necessarily specific to that radio, but these handhelds often have a "mode" button somewhere that toggles as either ON or OFF (such as a monitor button) - if you have pressed such a button inadvertently, you can tie them up...if so, press it again and all might be
497367
