mounting arm and bracket for sat dish for caravan
Submitted: Monday, Oct 29, 2012 at 09:36
ThreadID: 98772 Views:10218 Replies:7 FollowUps:6
Hi all we are looking to mount our sat dish on the rear bumper of the caravan is there a bracket and arm available if not what suggestions do you have for manufacturing one. The arm needs to be moveable and be able to extend.
Any ideas would be appreciated.
Terry
Reply By: Geoff in SA - Monday, Oct 29, 2012 at 12:26
Hi terry
I have mine mounted on the plate on the drawbar of the van.
It is mounted on the flat plate the tow hitch connects to
I use a piece of 16g exhaust tube and fix it with a length of 12mm threaded rod
The rod runs the full length of the tube and the tube has a cap on the top with a 12mm hole.
Just drill a 13mm hole in the plate and install the rod, add a nut and washer to the bottom and tighten at the top
Once tight it doesnt move.
Just point the dish where it needs to go. About 30 NE or something.
I do not travel with the dish or tube assembly as too many vibrations for the dish
Geoff
AnswerID: 497567
Follow Up By: Geoff in SA - Monday, Oct 29, 2012 at 12:28
you could do the same for the rear bumper if the van was not situated so as to be able to get the sat lined up
FollowupID: 773407
Reply By: Terry1950 - Monday, Oct 29, 2012 at 12:39
Thanks for that info it gives me something to work with.
Terry
AnswerID: 497570
Follow Up By: Geoff in SA - Monday, Oct 29, 2012 at 12:46
simplest is always easier and better
FollowupID: 773410
hope the description made sense
FollowupID: 773411
Follow Up By: Terry1950 - Monday, Oct 29, 2012 at 13:04
Thanks Geoff it made sense.
Terry also in SA
FollowupID: 773413
Reply By: i'machocoholic - Monday, Oct 29, 2012 at 14:23
We too have ours mounted like Geoff using exhaust pipe which we had bent specifically to our requirements.
Our sat dish travelled on the rear bumper attached to the exhaust pipe around Oz for 15 months - we had no issues with vibration. Many people would come and check out our set up to see how it was mounted.
As we used a "trailamate" type of jockey wheel which my better half made a bracket for on our A frame, it meant that we weren't using the original jockey wheel bracket on the A frame. Then, when we required the sat dish to be mounted at the front of the van so we could get signal, we just moved the sat dish and pipe from the rear bumper and used the original jockey wheel bracket to hold the exhaust pipe. We never required the original stand for the sat dish in all of our travelling which meant one less item to haul around. It worked a treat :-)
If you would like any pictures, I can arrange if it would help.
AnswerID: 497578
Reply By: Terry1950 - Monday, Oct 29, 2012 at 14:34
hI i'machocoholic great way you did it a photo or two would be appreciated..
Terry
AnswerID: 497579
Follow Up By: i'machocoholic - Thursday, Nov 01, 2012 at 09:18
Sorry Terry I can't post photos on here as I'm not a paying member.
If you would like any, please let me know your email address.
Linda.
FollowupID: 773536
Follow Up By: Terry1950 - Thursday, Nov 01, 2012 at 14:04
email brotell@gmail.com
Terry
FollowupID: 773547
Reply By: Member - Rod N (QLD) - Monday, Oct 29, 2012 at 14:36
Have a look at this thread on Caravaners Forum Sat TV Dish Mounts
I mount and transport mine on straight pipe on the A frame. I have a second pipe on the rear bumper. Both are secured with a jockey wheel clamp.
AnswerID: 497580
Reply By: Terry1950 - Monday, Oct 29, 2012 at 14:51
Thank you for that thread had already seen it.
Terry
AnswerID: 497582
Reply By: Bill13 - Monday, Oct 29, 2012 at 20:41
Hi Terry, I have a few detailed photo's of the setup on the rear of my van that you may like. Email me at peeweewood@iinet.net.au if you wish.
Bill
AnswerID: 497594
