Wednesday, Oct 31, 2012 at 16:58
The
Fuel from the supplier is ultra pure and certified, with the special fittings so you don't come into contact with the
fuel. I would also suggest that It's sealed and ultra pure for a reason and you would invalidate the warranty. For the small amounts we use I'm happy to go with the certified product. If you we're running a really big system I guess the price and amount of
fuel might be an issue.
As I mentioned before the unit is nearly silent, We have an ARB roof top tent on our GU, and even with the
barn doors open at night it really hard to here the unit when it is on, even with the silence of the outback.
The unit also has a remote control/ display that comes with it and a container of "service fluid" You do not have to have the remote plugged in for the unit to work automatically. If however you build you unit in somewhere where you can't see the LED status lamps you can install the remote, it's simple CAP 5 LAN cable and then have the remotes display somewhere easy to read. It has LED status lights, and a liquid crystal backlit display that you can cycle through, status, indicating machine status, charge rate in AMPs, unit serial number and hours of operation. It also indicates when the
fuel tank is empty. You can get a module that allows automatic changeover from an empty
fuel tank to a new one, It can also SMS you to let you know for a remote backup site, that you need to go change the
tank. You can also harness several
fuel cels together for more Watts output, and have a single controller.
773492
