what will run 2 cf40 weaco per day
Submitted: Tuesday, Jan 20, 2004 at 03:55
Member - jtb
what will run 2 cf40 weaco per day ? ,have duel bats and thinking honda generator 50 amp reboot 1 hour a day putting 100% in my bats will prolong there life as
well as having a back up fridge , 1 will be fridge , 1 freezer, andi will have more space than than large fri -freezer ,solar panel ?? cheers jtbrather be fishing
Reply By: William - Tuesday, Jan 20, 2004 at 18:14
mate what turps are you drinking?
whatever it is mate this post is unintelligible and makes no damn sense
43710
Follow Up By: Member - Eric- Wednesday, Jan 21, 2004 at 08:24
and you thought I was bad
Venus Bay
306011
Reply By: Brett - Wednesday, Jan 21, 2004 at 22:33
Just remember that in a lot of cases the DC output from a portable generator is generally low current output. You may gain a higher and charge rate and get better efficency vs time worth out of your running generator if you plug in a stand alone battery charger to the AC side of you genny.
43873
Reply By: Member - Nigel (QLD) - Saturday, Jan 24, 2004 at 01:12
Your gonna want about 100-150 amps of charge a day depending on temperature and how many times the fridges are opened.
If you only run the generator once a day then you'd want 200-300Ah of battery depending on type (if you take wet cells below 50% they tend to die in 6-12 months).
Also just coz you have a 50amp charger doesn't mean that the battery will accept 50 amps of charge - again depends on battery type.
Charging batteries above 80% take lots of time, not lots of amps.
44178
